2022-06-04, 18:07
2022-06-04, 22:03
@bobbie digital Grouping error should now be fixed in beta.2, see if it works.
https://github.com/Mariusz89B/script.mtv...9.9.609_v2
2022-06-04, 22:30
(2022-06-04, 22:03)M89SE Wrote: [ -> ]@bobbie digital Grouping error should now be fixed in beta.2, see if it works.
Yes, adding channels to group is now fixed.....Thanks
Question: how do you go about removing a channel from a group? I clicked on the channel in the group, then options, then remove added channels - then a blank page comes up.
Is this how it should be done?
2022-06-04, 22:56
@bobbie digital When pressing remove option there should be a window visible with grouped channels, try out beta.3
https://github.com/Mariusz89B/script.mtv...9.9.609_v3
2022-06-04, 23:19
(2022-06-04, 22:56)M89SE Wrote: [ -> ]@bobbie digital When pressing remove option there should be a window visible with grouped channels, try out beta.3@M89SE
I installed beta v3. but the results is the same, the window pops up, but is empty with ok and cancel at the bottom.
2022-06-04, 23:57
2022-06-05, 00:52
@M89SE
Very strange, when I click on remove added channels, I do not get that pop up as in the pictures, for me another screen pops up with an image of light tubes, with 'remove added channels' at the top and okay and cancel at the bottom, I think the image may be from the MQ7 skin I am using. Could it be that my MQ7 skin is blocking this particular pop-up, while every other pop-up works?
2022-06-05, 07:58
@bobbie digital Oh I see, might be a bit confusing but you need to press the context button on the group itself and not the "Remove added channels" button at the bottom menu. The "Remove added channels" button in the EPG List section is for manually assigned channels added to the EPG list.
https://github.com/Mariusz89B/script.mtv...rite-group
2022-06-05, 21:05
(2022-06-05, 07:58)M89SE Wrote: [ -> ]@bobbie digital Oh I see, might be a bit confusing but you need to press the context button on the group itself and not the "Remove added channels" button at the bottom menu. The "Remove added channels" button in the EPG List section is for manually assigned channels added to the EPG list.
@M89SE
Okay, I press on the group itself, the new tab came up and I choose a channel to delete and click okay, went back to the sports group, channel was not deleted.
Now when I go back to options and click on the group itself, nothing happens, screen just refreshes itself.
Any ideas? Thanks.
2022-06-05, 21:17
@bobbie digital Not sure, as it's working fine here. :/
2022-06-06, 02:09
@M89SE
I tried everything and still no luck, are you using version 9.9.609-beta 3?
I change my skin back to estuary
I am on android Nvidia Shield, would that make a difference?
I added a new Group and the window popped up to add / remove channels. I added a channel, it worked, when I went back to add more channels, the page did not popup
I think there might be a corrupt file, if I should start over from scratch which files would I have to save. so that I do not have to waste time adding all my channels to strm files again?
Thanks again.
Thanks again.
2022-06-06, 06:07
@bobbie digital No, I'm using 9.9.610. I tried out removing channels from custom group on my Nvidia Shield and it's working fine, so probably you need to install the latest version. Else if that won't work please PM me a log file.
https://github.com/Mariusz89B/script.mtv...ag/9.9.610
2022-07-02, 11:14
2022-11-23, 00:08
It has been awhile since I have messed around with Kodi but have decided to get back into it. In doing so I DL the latest version of m-TVGuide and am now attempting to setup the EPG but for some reason when I launch m-TVGuide I am getting a message stating that, "no services selected, please enable services in addon settings." For the life of I cannot figure out where this setting is at. On an older version of m-TVGuide (9.9.4) I have running on my RPI the guide is working correctly but the settings page has changed with this new version.
How can I get rid of this message for I am going to associate an add-on with the channels I have in my EPG. I assume this is still possible for it was in the older versions of m-TVGuide.
2022-11-23, 00:27
My earlier post can be ignored for I installed the 9.9.4 version got it working then removed it but left the settings in place. Installed the latest version and now everything is working properly.
