Full Version: m-TVGuide
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Also while I am thinking about it for some reason whenever I change anything in M-TVguide it wants me to restart my PC. Simply closing Kodi and relaunching does not fix its issue with restarting. Is this by design or is something up with my setup?
@Dimension I'm not aware of any restart issues, could you be more specific on when this restarts occur? you could also send me a debug log. As for comments about python 2.7 is that I've implemented fixes for Kodi <18, the addons supports both python 2 and 3.
EDIT:
Have you checked if you added a EPG and saved? because is sounds to me that an EPG hasen't been provided in settings.
(2021-10-01, 21:59)M89SE Wrote: [ -> ]@Dimension I'm not aware of any restart issues, could you be more specific on when this restarts occur? you could also send me a debug log. As for comments about python 2.7 is that I've implemented fixes for Kodi <18, the addons supports both python 2 and 3.
EDIT:
After completing the setup wizard I am met with a window stating that Kodi will now exit which is then followed by Kodi closing out. I launch Kodi then attempt to open M-TVGuide and I am shortly there after met with with a window stating that M-TVGuide needs to restart. This message will continue to come up until I reboot my PC.
Here is the log file from me attempting to open the application: https://pastebin.com/efdMAqhZ
@Dimension Link to log is not working.
First startup should look like this:
1. After completing setup wizard, Kodi must be restarted.
2. On first run, m-TVGuide needs to restart due to skin update.
3. On second run, addon should start.
(2021-10-01, 22:22)M89SE Wrote: [ -> ]@Dimension Link to log is not working.
Try this one: https://pastebin.com/t00RQPsp
(2021-10-01, 22:26)Dimension Wrote: [ -> ]
Not working. Try the built in log uploader in m-TVGuide settings. Database -> Upload kodi log.
First startup looks like this:
This is exactly what it taking place. At least now I know that this is by design.
(2021-10-01, 22:27)M89SE Wrote: [ -> ]
I am getting a "Failed to upload log" message.
@Dimension Yes, but this is a one time only process. Otherwise, it should start on the first try.
Here is a dropbox DL Link: https://www.dropbox.com/s/m86ib6eelu1opuw/kodi.log?dl=0
(2021-10-01, 22:29)Dimension Wrote: [ -> ]
(2021-10-01, 22:26)Dimension Wrote: [ -> ]Try this one: https://pastebin.com/t00RQPsp
Strange, just tested it on Kodi v19 and log is uploaded. :/
(2021-10-01, 22:31)Dimension Wrote: [ -> ]
Ok, I see an error in the log.
EDIT:
Seems to be some sort of SSL Certificate error, there is something on your computer blocking access to download epg and upload log.
(2021-10-01, 22:33)M89SE Wrote: [ -> ]
(2021-10-01, 22:27)M89SE Wrote: [ -> ]Not working. Try the built in log uploader in m-TVGuide settings. Database -> Upload kodi log.
Well that is good news. I assume that the issue is going to end up being on my end.
(2021-10-01, 22:36)Dimension Wrote: [ -> ]
(2021-10-01, 22:31)Dimension Wrote: [ -> ]Here is a dropbox DL Link: https://www.dropbox.com/s/m86ib6eelu1opuw/kodi.log?dl=0
EDIT:
I'm not following you on this one. I am downloading the EPG from m34u and I do not get any error messages when the download takes place.
