Full Version: Unable to fetch metadata
First post, so be gentle.
I've setup the latest version of Kodi on a Firestick with attached USB storage. Kodi is loading up fine but will not fetch any metadata. It's not even trying. I've tried changing providers and forcing a scan. Tried the same USB stick/data on my laptop and it worked flawlessly.
Any suggestions? Cheers.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
