Full Version: How do File states work and can they be reset?
oops posted this in wrong section, should be here
This is related to Leia and Matrix, I am using Kodi portable and smb's
Can someone explain how the file states work in the Video sources -
Large square - not loaded to library
Small square - loaded into library
Tick - Watched
I add and scrape - items in source have a Small square
I change scraper (TMDb TV Shows to TVDb, Local Information only to TMDB or TVDB) and re-scrape, a mix of Large & Small squares - all are loaded into library
Tried rescan, removing video source and rescanning then all the source has Large squares - all are loaded into library
Also gone through the nfo's, deleted and rescanned using TMM beforehand, no change
What did work was renaming the smb source for example Das 5 Films 5 to Das 5 Films 5a or Das 6 TV-Series 6 to Das 6 TV-Series 6a but that took ages
Checked logs nothing obvious.
OCD solution, which is quick:- restore and start again.
I can live with it and I know a workaround, can someone explain why?
