2021-09-29, 14:55
Hi, all.
Fisrt, i am not a programmer, nor have a huge background in python.
But i try to learn...
I just go over the methods descriped here
https://alwinesch.github.io/group__pytho..._list.html
to create contextmenu addon, as i thought it'll perform better to have such actions* handled by script than via xml skinning.
* = add item to playlist queue(last) | queue(as next)
... I came so far, that the actions itself seems correct.
But in my Custom Window the listitems, ARE'NT RETURNED | SEEMS not Available to the script.
And beside learn some stuff the script is mostly useless
(If i am in Media Window e.g. music,video ), it is working, but not in a custom window , which WAS THE ONLY APPROACH to do it.
The List Items itself are filled and existing in the window and the corresponding content|dbtype
May someone can help out whats going wrong here.
https://github.com/marduklev/context.playlist
queue song item - as next item
queue song item - as last item
Currently the only way to do so was via 'a hacky skin feature' , which seems a bit cumbersome....
- store labels in prop -> activate corresponding media window -> do builtin actions -> go back to custom window
The cyan colored context item labels use actions via xml, not via context addon which i liked to replace
https://streamable.com/3gbdtb
python:
# -*- coding: utf-8 -*-
import xbmc
import xbmcgui
def main():
playlist = xbmc.PlayList(xbmc.PLAYLIST_MUSIC)
songitem = xbmc.getInfoLabel('listitem.filenameandpath')
index = playlist.getposition() + 1
playlist.add(url=songitem, index=index)
xbmc.executebuiltin( 'Notification(Item Added,$INFO[listitem.Artist] - $INFO[listitem.Title])' )
if __name__ == '__main__':
main()
python:
import xbmc
import xbmcgui
def main():
playlist.add(url=songitem)
main()
