And there is no quick fix as that other path is required for the site to work on Android < 7.1 which only trusts DST Root CA X3, Android versions <7.1 dont care about CA cert expiry and continue to work
C:\>python
Python 3.8.10 (tags/v3.8.10:3d8993a, May 3 2021, 11:48:03) [MSC v.1928 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import urllib.request
>>> url = "https://mirrors.kodi.tv/addons/matrix/addons.xml.gz?sha256"
>>> req = urllib.request.Request(url)
>>> response = urllib.request.urlopen(req)
File "C:\Python38\lib\urllib\request.py", line 1354, in do_open
h.request(req.get_method(), req.selector, req.data, headers,
File "C:\Python38\lib\http\client.py", line 1252, in request
self._send_request(method, url, body, headers, encode_chunked)
File "C:\Python38\lib\http\client.py", line 1298, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "C:\Python38\lib\http\client.py", line 1247, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "C:\Python38\lib\http\client.py", line 1007, in _send_output
self.send(msg)
File "C:\Python38\lib\http\client.py", line 947, in send
self.connect()
File "C:\Python38\lib\http\client.py", line 1421, in connect
self.sock = self._context.wrap_socket(self.sock,
File "C:\Python38\lib\ssl.py", line 500, in wrap_socket
return self.sslsocket_class._create(
File "C:\Python38\lib\ssl.py", line 1040, in _create
self.do_handshake()
File "C:\Python38\lib\ssl.py", line 1309, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1131)
During handling of the above exception, another exception occurred:
File "<stdin>", line 1, in <module>
File "C:\Python38\lib\urllib\request.py", line 222, in urlopen
return opener.open(url, data, timeout)
File "C:\Python38\lib\urllib\request.py", line 525, in open
response = self._open(req, data)
File "C:\Python38\lib\urllib\request.py", line 542, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File "C:\Python38\lib\urllib\request.py", line 502, in _call_chain
result = func(*args)
File "C:\Python38\lib\urllib\request.py", line 1397, in https_open
return self.do_open(http.client.HTTPSConnection, req,
File "C:\Python38\lib\urllib\request.py", line 1357, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1131)>
gujal@mint-vm:~$ python3
Python 3.8.10 (default, Jun 2 2021, 10:49:15)
[GCC 9.4.0] on linux
>>> response.code
200
