Full Version: Team Kodi addons fail to update
I decided to reinstall Kodi on my Xbox one s. Then when I try to install from zip file the repository will install then 13 Team Kodi addons will fail to update.
*Team KODI failed to update
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
(2021-10-01, 21:31)Camlam Wrote: [ -> ]I decided to reinstall Kodi on my Xbox one s. Then when I try to install from zip file the repository will install then 13 Team Kodi addons will fail to update.
I am having this issue too I don't know how to fix it. Does anyone have any ideas on how to fix the issue? I can provide a debug log if that would be any help.
Notice the large important notice at top of forum page. Read that please
