2021-10-05, 11:18
I have a modal dialog which opens (extendedinfo_mod) and I would like to have it reopen after playback ends.
However I have tried various methods of storing the dialog variable and whatever way I store it leads to jerky playback:
The following will produce jerky video playback:
While this does not:
I've tried threading within and without the current procedure, ive tried pickling/dill (which doesnt work for cpython objects apparently) and any other method I can think of to store the variable and nothing appears to work.
I think its a graphical memory issue, this is on a Vero4k kodi box which will have a rasonable amount of ram but no dedicated graphics hardware. Therefore I think the dialog is stored in what little memory has been allocated to the graphics, and once it loads a bunch of stuff to the modal dialog this causes performance issues.
It doesnt appear to be an issue on windows.
Changing between "super(VideoPlayer, self).play(item=url, listitem=listitem, windowed=False, startpos=-1)" and "xbmc.executebuiltin('RunPlugin(%s)' % url)" does seem to have some performance benefit but the window is still jerky.
Does anyone know how I can completely close a window dialog AND store it for reopening without a significant performance impact?
Is there any reasonable way to store this in a file?
Any thoughts appreciated.
python:
def play_from_button(self, url, listitem, window=False, type='', dbid=0):
from resources.lib.WindowManager import wm
window2 = window
window.close()
window = None
del window
gc.collect()
del gc.garbage[:]
for i in range(600):
if xbmc.getCondVisibility('VideoPlayer.IsFullscreen'):
self.wait_for_video_end()
params = {'sender': addon_ID_short(),
'message': 'SetFocus',
'data': {'command': 'SetFocus',
'command_params': {'container': container, 'position': position}
command = json.dumps({'jsonrpc': '2.0',
'method': 'JSONRPC.NotifyAll',
'params': params,
'id': 1,
result = xbmc.executeJSONRPC(command)
wm.pop_stack2(window2)
window2 = None
del window2
gc.collect()
del gc.garbage[:]
return
xbmc.sleep(50)
return
python:
def play_from_button1(self, url, listitem, window=False, type='', dbid=0):
window.close()
gc.collect()
del window
return
