Full Version: Amber in Windows 10 Won't Start Addons
Whenever I try to start a addon nothing happens. It just gives me a blank background. It's not the addon because it works with other skins. I'm running Kodi 19.1 with amber mat. I hadn't used this computer for about a month.
(2021-10-08, 02:41)timmins Wrote: [ -> ]Whenever I try to start a addon nothing happens. It just gives me a blank background. It's not the addon because it works with other skins. I'm running Kodi 19.1 with amber mat. I hadn't used this computer for about a month.
@timmins, I am running Amber in Windows 10 with Kodi 19.1 and I have no issue with any of the addons I use. In order to evaluate the issue I will need a debug log of when the problem is happening. Please provide one. Thanks.
Regards,
Bart
(2021-10-08, 13:25)bsoriano Wrote: [ -> ]
Regards,
Bart
How do I get in the debug mode and where do I send it.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
(2021-10-08, 19:12)timmins Wrote: [ -> ]
Regards,
Bart
Using kodi logfile uploader try https://paste.kodi.tv/jubesanafa
I tried uninstalling Kodi and using my backup to restore it. I'm still getting the same results whenever I start a addon it doesn't show anything except the background screen. Other skins work find.
(2021-10-09, 00:18)timmins Wrote: [ -> ]
(2021-10-08, 13:25)bsoriano Wrote: [ -> ]@timmins, I am running Amber in Windows 10 with Kodi 19.1 and I have no issue with any of the addons I use. In order to evaluate the issue I will need a debug log of when the problem is happening. Please provide one. Thanks.
Regards,
Bart
As I mentioned that I had reinstalled kodi. After that I noticed allot of addons where disabled. When I re-enabled them it has started to work. Thanks for your time.
@timmins unfortunately, as your device contains several banned addons (wiki), by our piracy policy (wiki) support is not offered for it. Please see the forum rules (wiki) that you accepted and agreed to abide by when you signed up here for details.
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
