Full Version: Retrogaming skin support
Hi there all,
Hope somebody can help me out.
I want to play retrogames from kodi on my nvidia shield.
I just want to start te games from kodi, not from android.
But i want a netflix sort of look al like in the menu, so i want to have a top menu called GAMES. And the want some widgets like NES, SNES, SEGA etc.
Who can help me out?
(2021-10-11, 13:57)g.scholtens Wrote: [ -> ]Hi there all,
You can really only accomplish this currently with an addon. Check out AEL. It can do what you're looking to do.
(2021-10-11, 19:54)zachmorris Wrote: [ -> ]
With every skin? And must i use internet gaming archive or separate emulators
I hope i can help you, test "Titan-Mod", a gaming support was added by @chrisism under Kodi 18.
Unfortunately, i can not test it because, i do not use it.
NetFilx Similar views can be set.
See here with preview video: https://forum.kodi.tv/showthread.php?tid...pid2942996
Titan-Mod  Kodi Matrix: repository.fuchs246.zip
Titan-Mod  Kodi Leia: repository.marduk-1.0.5.zip
(2021-10-11, 20:15)g.scholtens Wrote: [ -> ]
Yes, IAGL works with different skins as well (I thought you were interested in a local library). Widgets work just fine as well for both AEL and IAGL. I personally use Aura and like the widget options it has.
(2021-10-12, 02:14)zachmorris Wrote: [ -> ]
(2021-10-11, 19:54)zachmorris Wrote: [ -> ]You can really only accomplish this currently with an addon. Check out AEL. It can do what you're looking to do.
No local roms yet, but that's no problem. I Just tested iagl and i very like the retro games. So i want to do more in kodi with retro games
