2021-10-11, 18:04
2021-10-11, 21:57
(2021-10-11, 18:04)buzzin Wrote: [ -> ]Can anybody point me in a direction, how do I even start solving this problem.Why are you trying to scrape addons?
xml:No information found for item 'zip://smb%3a%2f%2f192.168.31.59%2fmedia2%2fplugin.video.eurosportplayer-2.0.11.zip/', it won't be added to the library.
Do you have internet access on that hardware? There are quite a lot of errors in your log which makes me believe the problem is with your setup, rather than a problem with the scraper.
2021-10-11, 23:05
I've never seen a log quite like that. There are a huge slew of errors like this:
Which seems to indicate a file system error. Then Kodi appears to be invoking the TV show scraper but not sending any title at all. It doesn't even look like the scraper is being invoked properly at all, as I don't see some of the preference loads that I would normally expect to see. That doesn't seem like it should ever happen, so the lack of a title is not ever checked for. I could technically trap for that error, but all I would do is abort the scrape, because without a title there is literally nothing the scraper can do.
At a bare minimum you might want to try removing all your video sources and re-adding them to see if that helps. If not that, you might have to try something more extreme (like deleting the .kodi folder and/or reinstalling Kodi).
ERROR : InputStream: Error opening, videodb://movies/titles/10]
2021-10-12, 00:26
(2021-10-11, 21:57)Karellen Wrote: [ -> ](2021-10-11, 18:04)buzzin Wrote: [ -> ]Why are you trying to scrape addons?(2021-10-11, 21:57)Karellen Wrote: [ -> ]Can anybody point me in a direction, how do I even start solving this problem.(2021-10-11, 18:04)buzzin Wrote: [ -> ]Can anybody point me in a direction, how do I even start solving this problem.Why are you trying to scrape addons?
There are 5 references for repository.xvbmc lines 1771, 2389, 2991, 3599 and 4200, what does this contain?
