For some unknown reason, Amber isn't functioning on linux as it does on Windows. The issue relates to playlists. If I want to change the action of of a home screen menu item like "Movies", I select "Change Action" of what happens when you click the Movie button. The default is "ActivateWindow(Videos,vVdeoDB://Movies/Titles/.Return) and this works as expected.
If I want to change the action to instead show a playlist, I would in Windows Kodi, select Change Action->Video Library->Playlist (not playlistS) and I would be presented with a list of all the Video playlists, select one, and the new action would be a subset of all the movies depending on the playlist. In Windows, it's all good.
In Linux (Ubuntu), the list of playlists is empty with nothing to choose from, even though there are playlists in the /.kodi/userdata/playlists/video folder as evidenced by selecting the playlist button on the Movies sub menu. It's the same for any sub menu button as well. Movies-Sub Menu (Comedy) button. No way to select a playlist for the button. A workaround is select a Custom action and manually type in ActivateWindow(videos,special://profile/playlists/video/movies-comedy.xsp,return) which is what the result would have looked like had I been able to select the playlist by Change Action->Video Library->Playlist. Needless to say, that's not as expected.
I've tried several different PC's with different flavors of Ubuntu. The version of Kodi is 19.2 Matrix. Amber version is 3.4.11 from Kodi repository.
Thanks in advance for any ideas what might be happening.
(2021-10-17, 01:20)dpetr Wrote: [ -> ]For some unknown reason, Amber isn't functioning on linux as it does on Windows. The issue relates to playlists. If I want to change the action of of a home screen menu item like "Movies", I select "Change Action" of what happens when you click the Movie button. The default is "ActivateWindow(Videos,vVdeoDB://Movies/Titles/.Return) and this works as expected.
dpetr , I am not sure that this is an Amber issue. Could you please try another skin that uses script.skinshortcuts for the menu configuration and see if you have that same problem? You could try Aeon Nox Silvo or Arctic Horizon. I ask this to try to pinpoint if it is a skinshortctus error in Ubuntu. Thanks.
Also, it would be interesting if you could provide a debug log that shows when you are trying to add the playlist as a menu item and you get an empty list back. Perhaps there is something in the log that gives more of a clue of where the error is.
Regards,
Bart
You are absolutely correct. The other two skins have the same issue. The log files are littered with errors. I even get a Kodi crash log on every exit, so I suspect this isn't going to be an easy fix. I can post the logs, but it probably would be easier to load any version of ubuntu into a virtual machine if that is possible and have a go at it. A small portion of kodi.log:
2021-10-17 18:02:31.380 T:13684 INFO <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2021-10-17 18:02:31.383 T:13684 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup2shelvesbackground
2021-10-17 18:02:31.383 T:13684 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup3shelvesbackground
2021-10-17 18:02:31.383 T:13684 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup1
2021-10-17 18:02:31.383 T:13684 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup4
2021-10-17 18:02:31.383 T:13684 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup5
2021-10-17 18:02:31.383 T:13684 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup6
2021-10-17 18:02:31.383 T:13684 WARNING <general>: Skin has invalid include: skinshortcuts-template-ShelfIndicator
2021-10-17 18:02:31.384 T:13684 WARNING <general>: Skin has invalid include: skinshortcuts-template-ShelfOnUpMainMenu
2021-10-17 18:02:31.422 T:13745 INFO <general>: initializing python engine.
2021-10-17 18:02:31.544 T:13745 ERROR <general>: Skipped 1 duplicate messages..
2021-10-17 18:02:31.544 T:13745 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'ImportError'>
Error Contents: cannot import name 'favourites' from 'lib' (/usr/lib/python3/dist-packages/lib/__init__.py)
File "/home/harvester/.kodi/addons/script.favourites/default.py", line 2, in <module>
from lib import favourites
ImportError: cannot import name 'favourites' from 'lib' (/usr/lib/python3/dist-packages/lib/__init__.py)
2021-10-17 18:02:31.551 T:13745 INFO <general>: Python interpreter stopped
2021-10-17 18:02:31.860 T:13746 INFO <general>: CPythonInvoker(7, /home/harvester/.kodi/addons/script.skinshortcuts/default.py): script successfully run
2021-10-17 18:02:31.871 T:13746 INFO <general>: Python interpreter stopped
2021-10-17 18:02:45.411 T:13684 INFO <general>: Loading skin file: SkinSettings.xml, load type: LOAD_EVERY_TIME
2021-10-17 18:02:52.179 T:13780 INFO <general>: initializing python engine.
2021-10-17 18:02:52.445 T:13684 INFO <general>: Loading skin file: /home/harvester/.kodi/addons/skin.amber/1080i/script-skinshortcuts.xml, load type: LOAD_ON_GUI_INIT
2021-10-17 18:02:52.511 T:13782 ERROR <general>: GetDirectory - Error getting /home/harvester/.kodi/userdata/library/video
2021-10-17 18:02:52.512 T:13782 ERROR <general>: GetDirectory - Error getting /home/harvester/.kodi/userdata/library/music
2021-10-17 18:02:52.515 T:13782 ERROR <general>: GetDirectory - Error getting upnp://
2021-10-17 18:02:52.517 T:13782 ERROR <general>: Traceback (most recent call last):
2021-10-17 18:02:52.517 T:13782 ERROR <general>: File "/home/harvester/.kodi/addons/script.skinshortcuts/resources/lib/library.py", line 971, in playlists
for line in xmldata.getiterator():
2021-10-17 18:02:52.517 T:13782 ERROR <general>: AttributeError: 'xml.etree.ElementTree.Element' object has no attribute 'getiterator'
This is not right. Part of the same log. GetDirectory fails. With this many errors, you'd think nothing would work but it does mostly work!
2021-10-17 18:03:04.742 T:13684 INFO <general>: Loading skin file: /home/harvester/.kodi/addons/skin.amber/1080i/DialogSelect.xml, load type: LOAD_ON_GUI_INIT
2021-10-17 18:03:04.744 T:13684 ERROR <general>: Control 3 in window 13001 has been asked to focus, but it can't
2021-10-17 18:03:06.947 T:13684 INFO <general>: Loading skin file: /home/harvester/.kodi/addons/skin.amber/1080i/DialogSelect.xml, load type: LOAD_ON_GUI_INIT
2021-10-17 18:03:06.949 T:13684 ERROR <general>: Control 3 in window 13002 has been asked to focus, but it can't
2021-10-17 18:03:13.631 T:13684 INFO <general>: Loading skin file: /home/harvester/.kodi/addons/skin.amber/1080i/DialogSelect.xml, load type: LOAD_ON_GUI_INIT
2021-10-17 18:03:13.632 T:13684 ERROR <general>: Control 3 in window 13001 has been asked to focus, but it can't
2021-10-17 18:03:20.762 T:13684 INFO <general>: Loading skin file: /home/harvester/.kodi/addons/skin.amber/1080i/DialogSelect.xml, load type: LOAD_ON_GUI_INIT
2021-10-17 18:03:20.767 T:13684 ERROR <general>: Control 3 in window 13002 has been asked to focus, but it can't
2021-10-17 18:03:23.980 T:13684 INFO <general>: Loading skin file: /home/harvester/.kodi/addons/skin.amber/1080i/DialogSelect.xml, load type: LOAD_ON_GUI_INIT
2021-10-17 18:03:23.981 T:13684 ERROR <general>: Control 3 in window 13001 has been asked to focus, but it can't
2021-10-17 18:03:29.628 T:13780 INFO <general>: CPythonInvoker(8, /home/harvester/.kodi/addons/script.skinshortcuts/default.py): script successfully run
2021-10-17 18:03:29.642 T:13780 INFO <general>: Python interpreter stopped
2021-10-17 18:03:31.015 T:13828 INFO <general>: initializing python engine.
2021-10-17 18:03:31.019 T:13829 ERROR <general>: GetDirectory - Error getting settings
2021-10-17 18:03:31.019 T:13829 ERROR <general>: GetDirectory - Error getting SkinSettings
2021-10-17 18:03:31.019 T:13830 INFO <general>: initializing python engine.
2021-10-17 18:03:31.285 T:13830 ERROR <general>: Skipped 1 duplicate messages..
2021-10-17 18:03:31.285 T:13830 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
2021-10-17 18:03:31.286 T:13830 INFO <general>: Python interpreter stopped
2021-10-17 18:03:31.751 T:13831 INFO <general>: CPythonInvoker(11, /home/harvester/.kodi/addons/script.skinshortcuts/default.py): script successfully run
2021-10-17 18:03:31.764 T:13831 INFO <general>: Python interpreter stopped
2021-10-17 18:03:31.929 T:13828 INFO <general>: CPythonInvoker(9, /home/harvester/.kodi/addons/script.skinshortcuts/default.py): script successfully run
2021-10-17 18:03:31.940 T:13828 INFO <general>: Python interpreter stopped
2021-10-17 18:03:31.954 T:13684 INFO <general>: Unloaded skin
2021-10-17 18:03:31.954 T:13684 INFO <general>: load skin from: /home/harvester/.kodi/addons/skin.amber/ (version: 3.4.11)
(2021-10-18, 03:47)dpetr Wrote: [ -> ]You are absolutely correct. The other two skins have the same issue. The log files are littered with errors. I even get a Kodi crash log on every exit, so I suspect this isn't going to be an easy fix. I can post the logs, but it probably would be easier to load any version of ubuntu into a virtual machine if that is possible and have a go at it. A small portion of kodi.log:
dpetr , in the log snippets that you posted I do see a skinshortcuts error that could be the cause of the issue for you. Could you please use the latest skinshortcuts (not yet on the kodi repo):
https://github.com/mikesilvo164/script.s...master.zip
Download that zip, remove the -master from the end of the folder name inside the zip file, and just overwrite the current script.skinshortcuts folder with the contents from the zip file. Quit Kodi before doing this. I think this new version might have fixes that address the issue you are having.
Please let me know how it goes. Thanks.
Regards,
Bart
Also which part of "
Do not post logs in the forum. Use https://paste.kodi.tv/ instead." was unclear, just so we can correct it?
(2021-10-18, 18:01)DarrenHill Wrote: [ -> ]Also which part of "Do not post logs in the forum. Use https://paste.kodi.tv/ instead." was unclear, just so we can correct it?
DarenHill: Never read that...sorry. It's sort of like the fine print at the bank...never read that either. Your comment was funny. That's the only reason I'll remember to not do that again. It's a human shortcoming called old age. I cant even remember what happened a few hours ago without some unique reason to remember what happened.
bsoriano: Regards to tip about script.skinshortcuts-master. Indeed this solved the issue. Odd they couldn't update that so as to not encounter this problem. In any event, your wisdom was the key and for that I'm grateful. Спасибо - Thanks
