(2021-10-17, 15:25)buzzin Wrote: [ -> ]Just downloaded the 19.2, Windows 10, upgraded from 18.8. Kodi wont start, in the Task manager-details, the process just shows up for a second and then dissapears.
The Event Viewer has this event:
Faulting application name: Kodi.exe, version: 19.1.0.0, time stamp: 0x615d6dbe
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1202, time stamp: 0xc9db1934
Exception code: 0xe06d7363
Fault offset: 0x0000000000034f99
Faulting process id: 0xd44
Faulting application start time: 0x01d7c3587a54481f
Faulting application path: C:\Program Files (x86)\Kodi\Kodi.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 9813b2ea-a9ae-413c-8093-0749cb6fe3ee
Faulting package full name:
Faulting package-relative application ID:
And although I just installed 19.2 and the setup file clearly says 19.2, this error refers to 19.1. (?)
Ok, kodi.exe has 19.1.0.0 as "File version", and 19.2 as "Product version".
But still, it just crashes right away.
This is the kodi_stacktrace file: (just two lines)
Thread 26332 (process 26076)
# 0
this is the kodi.log file:
2021-10-17 15:26:31.246 T:26332 INFO <general>: -----------------------------------------------------------------------
2021-10-17 15:26:31.247 T:26332 INFO <general>: Starting Kodi (19.2 (19.2.0) Git:20211006-52c19a0728). Platform: Windows NT x86 64-bit
2021-10-17 15:26:31.247 T:26332 INFO <general>: Using Release Kodi x64
2021-10-17 15:26:31.247 T:26332 INFO <general>: Kodi compiled 2021-10-06 by MSVC 191627045 for Windows NT x86 64-bit version 10.0 (0x0A000007)
2021-10-17 15:26:31.247 T:26332 INFO <general>: Running on Windows 10 21H1, kernel: Windows NT x86 64-bit version 10.0.19043.1288
2021-10-17 15:26:31.247 T:26332 INFO <general>: FFmpeg version/source: 4.3.2-Kodi
2021-10-17 15:26:31.247 T:26332 INFO <general>: Host CPU: Intel® Core i7-4770 CPU @ 3.40GHz, 8 cores available
2021-10-17 15:26:31.247 T:26332 INFO <general>: System has 32.0 GB of RAM installed
2021-10-17 15:26:31.247 T:26332 INFO <general>: Desktop Resolution: 1920x1080 32Bit at 144Hz
2021-10-17 15:26:31.247 T:26332 INFO <general>: Running with restricted rights
2021-10-17 15:26:31.247 T:26332 INFO <general>: Aero is enabled
2021-10-17 15:26:31.247 T:26332 INFO <general>: Display is not HDR capable or cannot be detected
2021-10-17 15:26:31.247 T:26332 INFO <general>: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
2021-10-17 15:26:31.247 T:26332 INFO <general>: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
2021-10-17 15:26:31.247 T:26332 INFO <general>: special://xbmcbinaddons/ is mapped to: C:\Program Files (x86)\Kodi/addons
2021-10-17 15:26:31.247 T:26332 INFO <general>: special://masterprofile/ is mapped to: C:\Users\mestar\AppData\Roaming\Kodi\userdata
2021-10-17 15:26:31.247 T:26332 INFO <general>: special://home/ is mapped to: C:\Users\mestar\AppData\Roaming\Kodi\
2021-10-17 15:26:31.248 T:26332 INFO <general>: special://temp/ is mapped to: C:\Users\mestar\AppData\Roaming\Kodi\cache
2021-10-17 15:26:31.248 T:26332 INFO <general>: special://logpath/ is mapped to: C:\Users\mestar\AppData\Roaming\Kodi\
2021-10-17 15:26:31.248 T:26332 INFO <general>: The executable running is: C:\Program Files (x86)\Kodi\kodi.exe
2021-10-17 15:26:31.250 T:26332 INFO <general>: Local hostname: mestar-PC
2021-10-17 15:26:31.250 T:26332 INFO <general>: Log File is located: C:\Users\mestar\AppData\Roaming\Kodi\kodi.log
2021-10-17 15:26:31.250 T:26332 INFO <general>: -----------------------------------------------------------------------
2021-10-17 15:26:31.250 T:26332 INFO <general>: loading settings
2021-10-17 15:26:31.251 T:26332 INFO <general>: special://profile/ is mapped to: special://masterprofile/
2021-10-17 15:26:31.257 T:26332 INFO <general>: No settings file to load (special://xbmc/system/advancedsettings.xml)
2021-10-17 15:26:31.257 T:26332 INFO <general>: No settings file to load (special://masterprofile/advancedsettings.xml)
2021-10-17 15:26:31.257 T:26332 INFO <general>: Default Video Player: VideoPlayer
2021-10-17 15:26:31.257 T:26332 INFO <general>: Default Audio Player: paplayer
2021-10-17 15:26:31.257 T:26332 INFO <general>: Disabled debug logging due to GUI setting. Level 0.
2021-10-17 15:26:31.257 T:26332 INFO <general>: Log level changed to "INFO"
2021-10-17 15:26:31.257 T:26332 INFO <general>: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2021-10-17 15:26:31.262 T:26332 INFO <general>: creating subdirectories
2021-10-17 15:26:31.262 T:26332 INFO <general>: userdata folder: special://masterprofile/
2021-10-17 15:26:31.262 T:26332 INFO <general>: recording folder:
2021-10-17 15:26:31.262 T:26332 INFO <general>: screenshots folder:
2021-10-17 15:26:31.265 T:26332 ERROR <general>: SQL: [Addons33.db] SQLite error SQLITE_ERROR (no such table: version)
Query: SELECT idVersion FROM version
So, something about SQLITE error, this is just after running setup twice.
So, what's my next move?
