Good day to all.
I just installed Kodi 19.2 on my Android TV.
In the settings then adjusted the workgroup and my language (German).
After inserting the souces and the first indexes comes permanently The Movie Database Python Error.
I should check the log to which I unfortunately do not get.
Can someone please give me some tips on how to fix this error?
TV restart did not help either.
Have a wonderful day.
With kind regards Unitec
Translated with
www.DeepL.com/Translator (free version)
(2021-10-19, 13:58)Unitec Wrote: [ -> ]I should check the log to which I unfortunately do not get.
A
debug log (wiki) file is always started. Use the Kodi Log Uploader add-on so we can see what is going on internally.
(2021-10-19, 16:22)Klojum Wrote: [ -> ] (2021-10-19, 13:58)Unitec Wrote: [ -> ]I should check the log to which I unfortunately do not get.
A debug log (wiki) file is always started. Use the Kodi Log Uploader add-on so we can see what is going on internally.
Hi Klojum
i will do my best to get the Loguploader installed.
Greetings Unitec.
Hi Klojum,
had the Log Uploader installed and thats the URL:
gufukenoda (paste)
I have reinstalled Kodi :
Deinstall -> Reboot TV
Install Kodi with First Startup and Network settings -> Reboot TV
Starting Kodi and setting up the SMB Shares.
Adding some Videos using one of the Shares.
And the Messages are Popping up.
Stoped the INDEXING and Uploaded the Log.
Greeting Unitec.
Hope i done it right with the Log.
Unitec
It is a known issue, but we are just waiting for the scraper developer to show up. He is MIA.
Switch to the XML scraper and the problem will go away.
HI Karellen,
thanks for the info i will try it asap.
Have an nice Day.
Greetings Unitec.
(2021-10-20, 11:54)kofii12345 Wrote: [ -> ]https://github.com/mkaflowski/mkaflowski...p?raw=true
This should work.
I will make pull request for repo.
Edit:
I see that it is PR by rmrector already.
My fault with not testing one use-case. Sorry for that.
HI kofii12345
Sorry for the late reply. My mistake.
The fix / download is working fine.
And we are all human and can make a mistake and forget something.
Thanks to all of you for your help.
Many greetings and stay healthy
Unitec
