How can I change the language from English to Italian?
On settings in the Add-ons screen- Settings>Add-ons>My Add-ons>Information Providers>Movie information and changed Preferred Language and Preferred Certification Country on IT but I always see the information in English
I find the problem on Android Kodi while on the W version of default the information is in Italian but I can't find where the source is set
di seguito il file log:
mod edit - log spam moved to https://paste.kodi.tv/tabehikopu.kodi
Do not post logs directly to the forum - that's what our paste site is for.
There's a small and subtle hint above the posting buttons -
Do not post logs in the forum. Use https://paste.kodi.tv/ instead.
(2021-10-20, 16:07)donnje Wrote: [ -> ]On settings in the Add-ons screen- Settings>Add-ons>My Add-ons>Information Providers>Movie information and changed Preferred Language and Preferred Certification Country on IT but I always see the information in English
Yes, we think there is a bug in the scraper. We are looking into it. Hopefully it won't take too long to fix. You can change to the XML scraper if you are in a hurry to scrape.
Item 7 in the first image...
https://forum.kodi.tv/showthread.php?tid=363391
So is it a bug found by other users? can I do some tests such as deleting the scraper file so that it regenerates it?
If I have not misunderstood I set on Item 7 I changed the language but nothing has changed or did I not understand?
Thx
(2021-10-20, 21:56)donnje Wrote: [ -> ]So is it a bug found by other users?
Yes, reported here...
https://github.com/xbmc/metadata.themovi...-947484733
(2021-10-20, 21:56)donnje Wrote: [ -> ]If I have not misunderstood I set on Item 7 I changed the language
I suggested you change scraper until the problem is fixed. (or you can wait for the fix)
Item 7 is another scraper. Switch to that scraper in setting
5b then adjust the language in
5c
(2021-10-20, 22:02)Karellen Wrote: [ -> ] (2021-10-20, 21:56)donnje Wrote: [ -> ]So is it a bug found by other users?
Yes, reported here... https://github.com/xbmc/metadata.themovi...-947484733
Item 7 is another scraper. Switch to that scraper in setting 5b then adjust the language in 5c
Excuse my bad English and thanks for your patience
I changed on 5b the scrapers from Python to The movies database, changed to IT language, upgraded library and now I see the scrapers in Italian
is the bug only on python?
Python is preferable because the best?
(2021-10-21, 16:02)donnje Wrote: [ -> ]is the bug only on python?
Yes. We are trying to fix. Hopefully in the next day or two you will see an update come through.
Thanks you write me if you have a news
