Full Version: how to extract zips on kodi?
how to extract zips in kodi either by script or command?, i need it to be compatible with kodi 18.9 and 19.2 Matrix
Edit: it was suffered but I found it
import six
from kodi_six import xbmc, xbmcvfs, xbmcgui, xbmcplugin, xbmcaddon
try:
    from urllib.parse import urlparse, parse_qs, quote, unquote, quote_plus, unquote_plus, urlencode #python 3
except ImportError:
    from urlparse import urlparse, parse_qs #python 2
    from urllib import quote, unquote, quote_plus, unquote_plus, urlencode
def unzip(path, dest, format):
    path = quote_plus(path)
    root = format + '://' + path + '/'
    dirs, files = xbmcvfs.listdir(root)
    if dirs:
        unzip_recursive(root, dirs, dest)
    for file in files:
        if six.PY3:
            unzip_file(os.path.join(root, file), os.path.join(dest, file))
        else:
            unzip_file(os.path.join(root, file.decode('utf-8')), os.path.join(dest, file.decode('utf-8')))
def unzip_recursive(path, dirs, dest):
    for directory in dirs:
        if six.PY3:
            dirs_dir = os.path.join(path, directory)
            dest_dir = os.path.join(dest, directory)
        else:
            dirs_dir = os.path.join(path, directory.decode('utf-8'))
            dest_dir = os.path.join(dest, directory.decode('utf-8'))
        xbmcvfs.mkdir(dest_dir)
        dirs2, files = xbmcvfs.listdir(dirs_dir)
        if dirs2:
            unzip_recursive(dirs_dir, dirs2, dest_dir)
        for file in files:
            if six.PY3:
                unzip_file(os.path.join(dirs_dir, file), os.path.join(dest_dir, file))
            else:
                unzip_file(os.path.join(dirs_dir, file.decode('utf-8')), os.path.join(dest_dir, file.decode('utf-8')))
def unzip_file(path, dest):
    ''' Unzip specific file. Path should start with zip://
    xbmcvfs.copy(path, dest)
Example:
    file = path+'/file.zip'
    if file.endswith(".zip"):
        unzip('path_zip','destination','zip')
    elif file.endswith(".rar"):
        unzip('path_rar','destination','rar')
(2021-10-22, 03:37)mitomitoso Wrote: [ -> ]i need it to be compatible with kodi 18.9 and 19.2 Matrix
In case you didn't know, Kodi 18 and 19 each support a different Python version. That could be important, but I'm not sure at this point.
Other than that, which type of files in zips does Kodi need to extract?
(2021-10-22, 08:14)Klojum Wrote: [ -> ]
could show me separately, I have a subtitle addon that I'm making compatible with kodi 18.9 and 19.2 using "kodi-six" and "six" modules, I need code to extract .zip and another to extract .rar
I already found it, tank you
(2021-10-22, 23:49)mitomitoso Wrote: [ -> ]I already found it, tank you
Perhaps you can also outline the solutions in case others have the same problem.
