Full Version: Movies won't scrape
Pages: 1 2
Dear all,
i had a issue, withe TMDB, i know there has a fix about the year.
I use a libereelec 19.1 on a Pi4.
sorry for the logs, i don find a upload icon.
could you please give a advice what is wrong. i must need chane the movie names with year.
Thank you very much for help.
Kind regards
2021-11-09 08:38:15.814 T:1047 DEBUG <general>: VideoInfoScanner: Skipping dir '/media/anna/dvd/Der Adler der Neunten Legion (2011)/' due to no change (fasthash)
2021-11-09 08:38:15.815 T:1047 DEBUG <CAddonSettings[metadata.themoviedb.org.python]>: trying to load setting definitions from old format...
2021-11-09 08:38:15.817 T:1047 DEBUG <general>: VideoInfoScanner: Skipping dir '/media/anna/dvd/Der goldene Kompass/' due to no change (fasthash)
2021-11-09 08:38:15.818 T:1047 DEBUG <CAddonSettings[metadata.themoviedb.org.python]>: trying to load setting definitions from old format...
2021-11-09 08:38:15.820 T:1047 DEBUG <general>: VideoInfoScanner: Skipping dir '/media/anna/dvd/Der Große Gatsby/' due to no change (fasthash)
2021-11-09 08:38:15.821 T:1047 DEBUG <CAddonSettings[metadata.themoviedb.org.python]>: trying to load setting definitions from old format...
2021-11-09 08:38:15.822 T:1047 DEBUG <general>: VideoInfoScanner: Skipping dir '/media/anna/dvd/Der Hypnotiseur/' due to no change (fasthash)
2021-11-09 08:38:15.823 T:1047 DEBUG <CAddonSettings[metadata.themoviedb.org.python]>: trying to load setting definitions from old format...
2021-11-09 08:38:15.825 T:1047 DEBUG <general>: VideoInfoScanner: Skipping dir '/media/anna/dvd/Der Mandant/' due to no change (fasthash)
2021-11-09 08:38:15.826 T:1047 DEBUG <CAddonSettings[metadata.themoviedb.org.python]>: trying to load setting definitions from old format...
2021-11-09 08:38:15.827 T:1047 DEBUG <general>: VideoInfoScanner: Skipping dir '/media/anna/dvd/Der Plan/' due to no change (fasthash)
2021-11-09 08:38:15.828 T:1047 DEBUG <CAddonSettings[metadata.themoviedb.org.python]>: trying to load setting definitions from old format...
2021-11-09 08:38:15.830 T:1047 DEBUG <general>: VideoInfoScanner: Skipping dir '/media/anna/dvd/Die Jugger – Kampf der Besten/' due to no change (fasthash)
2021-11-09 08:38:15.831 T:1047 DEBUG <CAddonSettings[metadata.themoviedb.org.python]>: trying to load setting definitions from old format...
2021-11-09 08:38:15.832 T:1047 DEBUG <general>: VideoInfoScanner: Skipping dir '/media/anna/dvd/Die Logan Verschwoerung/' due to no change (fasthash)
2021-11-09 06:00:52.152 T:1084 INFO <general>: [metadata.themoviedb.org.python]: Find movie with title 'title00' from year '0'
2021-11-09 06:00:52.716 T:1084 INFO <general>: CPythonInvoker(8, /storage/.kodi/addons/metadata.themoviedb.org.python/python/scraper.py): script successfully run
2021-11-09 06:00:52.717 T:1047 WARNING <general>: No information found for item '/media/anna/dvd/Asphalt Gorillas.mkv', it won't be added to the library.
2021-11-09 06:00:51.317 T:1064 INFO <general>: ## LibreELEC Addon ## updates:Confusedet_auto_update ## manual
2021-11-09 06:00:51.479 T:1084 INFO <general>: CPythonInvoker(8, /storage/.kodi/addons/metadata.themoviedb.org.python/python/scraper.py): script successfully run
2021-11-09 06:00:51.479 T:1047 WARNING <general>: No information found for item '/media/anna/dvd/2067 - Kampf um die Zukunft(2020).mkv', it won't be added to the library.
2021-11-09 06:00:51.590 T:1084 INFO <general>: initializing python engine.
2021-11-09 06:00:51.625 T:1084 INFO <general>: [metadata.themoviedb.org.python]: Find movie with title 'title00' from year '0'
@cokie72
I have split your post and moved you to the correct forum.
Could you explain in more detail what the problem is. The log snippet your provided is not helpful. We need the full Debug Log, as well as the names of the movie you are having problems with.
Check the movie at https://www.themoviedb.org/ to ensure it exists and you have named it correctly, and provide the link if you cannot find anything wrong with what you have done.
Dear Karellen,
thank you reply.
how i upload the Log here ?
And the issue is that the moves are not add to the Database / library with poster.
I check the Mives names every time over TMDB, exsample: '/media/anna/dvd/Warten auf die Barbaren.mkv'
Kind Regards
(2021-11-09, 11:07)cokie72 Wrote: [ -> ]how i upload the Log here ?
See the image...
(2021-11-09, 11:07)cokie72 Wrote: [ -> ]And the issue is that the moves are not add to the Database / library with poster.
Ok, understand. Capture the scraping of a movie in the log, and I will try to check what the problem is.
As you can see here... https://www.themoviedb.org/movie/505707-...es/posters there are no German posters. But you should still get English posters.
Here some exsample:
[metadata.themoviedb.org.python]: Find movie with title '1917 (2019)' from year '0'
2021-11-09 06:00:49.840 T:1084     INFO <general>: CPythonInvoker(8, /storage/.kodi/addons/metadata.themoviedb.org.python/python/scraper.py): script successfully run
2021-11-09 06:00:49.841 T:1047  WARNING <general>: No information found for item '/media/anna/dvd/1917(2019).mkv',
Kind Regards
Dear Karellen,
thank you very much for support. Hope the Log ist now uploaded.
Sorry, German poster are here also:
https://www.themoviedb.org/search?query=...uage=de-DE
the same is with : Der Fall Richard Jewell >  Der Fall Richard Jewell.mkv
https://www.themoviedb.org/search/movie?...uage=de-DE
no poster in UK (English) and they dont add the Movies to the DB/library Movies ........
(2021-11-09, 12:01)cokie72 Wrote: [ -> ]thank you very much for support. Hope the Log ist now uploaded.
You also need to provide the link to the log otherwise we will never find it.
It is Step 4 in the image above.
(2021-11-09, 12:17)cokie72 Wrote: [ -> ]Sorry, German poster are here also:
There are no German posters for this movie.
Good morning,
here the log:
https://paste.kodi.tv/dexezukici.kodi
Hello @cokie72
I can't see the issue in the log. The first log had debug mode enabled, but you did not scrape any movies, so I could not see what the scraper does.
The second log you scraped movies, but did not enable debug mode, so there was not enough info to see the cause.
So the issue is that movies are scraped without German poster, or no posters.
Can you tell me, in the scraper settings, in the Fanart.tv tab, what setting do you have for Enable artwork from Fanart.tv. Is it enabled or disabled, and what language have you set?
As shown in this image... https://kodi.wiki/view/Add-on:The_Movie_...9_-_Matrix
(2021-11-10, 10:05)Karellen Wrote: [ -> ]Hello @cokie72
Hello Karellen,
need now user because Admin give only 9 Post each day......but today i reply on 1 never mind...
artwork is enable with en.
(2021-11-10, 10:20)cokie72x Wrote: [ -> ]need now user because Admin give only 9 Post each day
Oh, no. Don't do that. I will need to close the new account now. I will give you more posts on your other account.
(2021-11-10, 10:20)cokie72x Wrote: [ -> ]artwork is enable with en.
Ok, I think this might be what is causing the problem.
When fanart.tv is enabled, there is no fallback language. If the artwork in your specified language does not exist, then you get nothing.
For your movie Waiting for the Barbarians, this is what fanart.tv has and you will notice there are no German posters... https://fanart.tv/movie/505707/waiting-f...arbarians/
Can you disable fanart.tv and see if you get the posters.
Pages: 1 2
