Hello
I keep getting this message every time I open Kodi on my Xbox now. I can close it but it just pops up again and again... Then after a bit Kodi will load.
The thing is this never used to happen. Is my Kodi corrupted in some way?
Clear your cache on your xbox by disconnecting from power source and pressing xbox power button for 5 secs after unplugging
I have the same issue , tried clearing the cache by two different methods (The Blu-ray method and the power method mentioned above) neither solved the problem.
Kodi is the only app that gives me this message , doing a little search i found this same message can happen to games too in which case it seems the only solution is to
Uninstall then re-install the game.
Try clear catch, then uninstall, and then reinstall. it might work
Xbox seems to have introduced an issue that causes this for a random app in their last update. For me, it's happening to the Youtube app, and I've seen reports of it happening to Shudder as well.
