Full Version: Set content over UPNP??
Pages: 1 2 3 4 5
That's the error from your log. Please delete the video database and reboot
2021-11-26 20:32:51.360 T:606 ERROR <general>: SQL: [MyVideos120.db] SQLite error SQLITE_ERROR (no such table: import)
Query: SELECT source.identifier, import.media_type, import.last_sync, import.settings FROM import JOIN source ON source.source_id = import.source_id
2021-11-26 20:32:51.360 T:606 ERROR <general>: GetImports unable to GetImports (SELECT source.identifier, import.media_type, import.last_sync, import.settings FROM import JOIN source ON source.source_id = import.source_id)
Both machines please. Chances are the database upgrade did not complete properly. MediaImport adds new fields to the database.
Done, same issue. Here is the log:
https://pastebin.com/uWsSMVNn
2021-11-26 20:58:04.101 T:618 INFO <general>: Old database found - updating from version 119 to 120
It is still trying to update the database. Just rename the database folder to databaseold
You mean the whole database folder?
yes. Kodi will replace on startup
So any more ideas? And thank you for taking The time to help! I really appriciate it.
Give me a few. Trying to get a second opinion.
Of course. I need to sleep soon. Work tomorrow. Will check this thread asap Smile
While we wait could you try the build linked. It has a few LibreELEC updates
Edit: link removed
The second opinion that I sought was that of the Developer, Montellese. It seems that you found a bug in the database routines. It has been fixed and i ran a new build. both the tar and img files are linked below. Just drop either into the update folder. to be safe rename or delete the database folder.
https://drive.google.com/file/d/1-FW-t9x...sp=sharing
https://drive.google.com/file/d/1iVIOfls...sp=sharing
Let us know how it goes.
Cheers,
LongMan
Oh awesome. I hope that it fixed it. Will report back tonight when im home Smile
Update! After the update, it detected the main one as soon as i booted. Thank you very much for all your help! Fyi this is exactly what i was looking for!
@LongMan when i try to play something from the library i get "this file is no longer available would you like to remove it from your library". hmm?
Pages: 1 2 3 4 5
