Star plus channel not working with kodi even though valid subscription of jio tv and disney+ hotstar is logged in through kodi. Error coming as ''use jio network to play this content" with hotstar icon and network error tag.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Dear Team,
Please find the below link for debug logs where i am getting above mentioned error for star channels.
https://paste.kodi.tv/pewagusigi.kodi
Please look into it and do the needful as i am unable to play any star channel with valid hotstar subscription on kodi home screen.
That log has only the first 85 lines. We would like the full log file.
