Within the last couple of weeks or so all three of my Amber installs have gone down. On all three I get a error that says "Unable to Build Menu - Upload debug Log". Other than this everything is working perfectly. I have two shields and a windows 10 install. Tried updating amber but all I get afterwards is a black screen with no control. What can I do to get rid of this error. I'm willing to start a new.
Thanks for any help.
It hasn't worked completely, I'm still getting " Unable to Build Menu". How do I install this fix. I used the " Install from Zip" is this what I have to do. Any requirement to uninstall version 2 first.
(2021-12-05, 00:58)timmins Wrote: [ -> ]It hasn't worked completely, I'm still getting " Unable to Build Menu". How do I install this fix. I used the " Install from Zip" is this what I have to do. Any requirement to uninstall version 2 first.
After reading farer, I noticed that other people had the same problem. It was mentioned that they had blocked updates. After doing that everything is working fine again
Can I make a suggestion for this site. On the main incoming page make a post heading called something :ANNOUNCEMENTS or whatever you want. In there put issues like this on. After reading through the posts this issue came up almost a dozen times. This would save allot of time for yourself and anybody who has the issue.
