2021-12-05, 12:12
I have been working on adding a new view to my skin and while it is basically working, there are a couple of issues that I can't figure out how to resolve. Could someone please offer some suggestions?
This is a screengrab of the view at the moment.
So the problems at the moment are:
Wyrm
<include name="CategoryLabel">
<definition>
<control type="label" id="$PARAM[list_id]2">
<left>0</left>
<top>5</top>
<width>689</width>
<height>50</height>
<font>apptv20</font>
<align>left</align>
<label>$PARAM[label]</label>
<visible>$PARAM[list_visible]</visible>
<visible>Container(59).IsUpdating | Integer.IsGreater(Container(59).NumItems,1) | Container($PARAM[list_id]).IsUpdating | Integer.IsGreater(Container($PARAM[list_id]).NumItems,0)</visible>
</control>
</definition>
</include>
<include name="WidgetListPoster">
<param name="content_path"></param>
<param name="widget_header"></param>
<param name="list_id"></param>
<param name="list_visible"></param>
<definition>
<include content="CategoryLabel">
<param name="label" value="$PARAM[widget_header]"/>
<param name="list_id" value="$PARAM[list_id]"/>
<param name="list_visible" value="$PARAM[list_visible]"/>
</include>
<include content="page-offscreen-horizontal">
<param name="indicator1left" value="0"/>
<param name="indicator1top" value="-185"/>
<param name="indicator2left" value="1872"/>
<param name="indicator2top" value="-185"/>
<param name="indicatorsize" value="32"/>
<param name="indicatorcontainer" value="$PARAM[list_id]"/>
</include>
<control type="panel" id="$PARAM[list_id]">
<left>0</left>
<top>55</top>
<width>1800</width>
<height>260</height>
<scrolltime tween="cubic" easing="out">200</scrolltime>
<orientation>horizontal</orientation>
<onleft>9000</onleft>
<onright>9000</onright>
<itemlayout width="200">
<control type="image">
<left>40</left>
<top>10</top>
<width>120</width>
<height>158</height>
<aspectratio scalediffuse="false">stretch</aspectratio>
<texture diffuse="mask-rect.png" background="true">$VAR[IconPoster]</texture>
</control>
</itemlayout>
<focusedlayout width="200">
<left>40</left>
<top>10</top>
<width>120</width>
<animation effect="zoom" start="100" end="106" center="auto" time="200" tween="back" easing="out" reversible="false">focus</animation>
</control>
<control type="textbox">
<left>0</left>
<top>170</top>
<height>62</height>
<width>200</width>
<font>apptv18</font>
<align>center</align>
<aligny>top</aligny>
<label>$INFO[ListItem.Label]</label>
<animation effect="fade" time="100" delay="100">Focus</animation>
<visible>Control.HasFocus($PARAM[list_id])</visible>
</control>
</focusedlayout>
<content target="$PARAM[widget_target]" limit="15">$PARAM[content_path]</content>
</control>
</definition>
</include>
<include name="WidgetView">
<control type="fixedlist" id="59">
<viewtype label="31973">list</viewtype>
<left>-10</left>
<top>-10</top>
<width>1</width>
<height>1</height>
<onfocus>SetFocus(5900)</onfocus>
<onback>SetFocus(59)</onback>
<itemlayout/>
<focusedlayout/>
</control>
<control type="grouplist" id="5900">
<left>75</left>
<top>110</top>
<height>930</height>
<width>1890</width>
<itemgap>0</itemgap>
<align>left</align>
<scrolltime tween="quadratic" easing="out">200</scrolltime>
<onup>Control.Move(59,-1)</onup>
<ondown>Control.Move(59,1)</ondown>
<orientation>vertical</orientation>
<visible>Control.IsVisible(59)</visible>
<include content="WidgetListPoster">
<param name="content_path" value="$VAR[WidgetViewList0]"/>
<param name="widget_header" value="$INFO[Container(59).Listitem(0).Label]"/>
<param name="widget_target" value="videos"/>
<param name="list_id" value="5905"/>
<param name="list_visible" value="![String.IsEqual(Container(59).Listitem(0).Label,..)]"/>
</include>
<param name="content_path" value="$VAR[WidgetViewList1]"/>
<param name="widget_header" value="$INFO[Container(59).Listitem(1).Label]"/>
<param name="list_id" value="5910"/>
<param name="list_visible" value="![String.IsEqual(Container(59).Listitem(1).Label,..)]"/>
</include>
<param name="content_path" value="$VAR[WidgetViewList2]"/>
<param name="widget_header" value="$INFO[Container(59).Listitem(2).Label]"/>
<param name="list_id" value="5915"/>
<param name="list_visible" value="![String.IsEqual(Container(59).Listitem(2).Label,..)]"/>
</include>
<param name="content_path" value="$VAR[WidgetViewList3]"/>
<param name="widget_header" value="$INFO[Container(59).Listitem(3).Label]"/>
<param name="list_id" value="5920"/>
<param name="list_visible" value="![String.IsEqual(Container(59).Listitem(3).Label,..)]"/>
</include>
</control>
</include>
- For the first three (or four if parent item is turned off) I can scroll down and have the focused item show its focused item label. after that the focused item label is not shown, but can still scroll down the widget lists. If I use the mouse to bring the focus back to one of the items I can then continue to scroll without losing the display of the label.
- The arrows from page-offscreen-horizontal include display one above the other instead of appearing where I positioned them with the includes parameters. They are two seperate images with their own id numbers and that is basically it for the include. No groups , just two image controls.
- And this is the show stopper at this stage. View works pretty well from TV Show season level of library, but when I try to use the view with the Netflix addon, Kodi crashes back to the desktop. NO crashlog, no errors in Kodi's log file, just stops cold. Is this my code, or is this something to do with a couple bugs about URL's that are due to be fixed for 19.4?
Wyrm
