2021-12-06, 17:55
Hi there,
last week I had to format and re-install Windows 10 on my HTPC (Intel NUC7i3BNH) as the update routine failed and I had no working backup :-(
So I re-installed windows with basic functions and took my Kodi Installation with the portable folder, which normally should work.
But now I've the problem, that I always get only stereo sound with configured WASAPI Device..
I tried several options but nothing was working, only DirectSound is working.
I started Kodi also with default settings and configured only the Audio Options, but the same.. Only Stereo Sound.
In my mind there is a problem with the windows driver, but I don't know what and where I can configure it.
The hardware installation was not changed, so that should not be the problem (HTPC --> Yamaha RX-V675 --> Panasonic TX-P50VT50E)
I created also a debug log --> itiyiticoc.kodi (paste)
And here the (in my mind) relevant audio settings in Kodi.
Maybe someone has a tip what I can do
Thanks and best regards,
Shadow128
Shadow128
