2021-12-12, 23:44
Hi @phunkyfish
I powered up my shield yesterday after maybe 4-5 days and downloaded the latest app updates from the google store, then started Kodi which caused it to immediately crash after the main menu appeared and had started to import the channels. Tried this a number of times all resulting in the same behaviour. Have tried again today, but exactly the same thing is happening.
It's really quite odd, as the last time I used Kodi on the Shield was 4-5 days previously and everything was fine. The only difference I've made between then and now, is downloading the shield app updates.
I do also have the IPTV client enabled as well, but didn't mention that in the post title, as the only errors I can see on the debug log I obtained from the Shield all relate to the Enigma/VU+ Client. When I disable both of these PVR clients, Kodi seems remain on but seems to be running much slower at certain tasks. Like it took 15 minutes to scan 4 new movies into the library using an smb connection. Not sure if that has any relevance or just a pure coincidence.
Anyway, the enigma errors don't mean a whole load to me, but perhaps you could take a look when get a chance.
Log attached: kegibosivu.kodi (paste)
