Hello, any chance there is an update available for Kodi 19+? Time of this post, 19.3 is latest stable. If not, is there any other option available to remove the exit confirmation for estuary?
What do you mean by "remove the exit confirmation " ?
usamac Please don't use a random old thread to add your question, create your own thread. I've split off your post now.
Depending on your OS, Alt+F4 works fine in Windows and Linux to exit Kodi instantly.
Most likely it's related to remotes and their power button. Either if the remote is recognized as a keyboard or as a real remote one shows the shutdown menu. This can be configured using a custom keyboard.xml or remote.xml file to directly turn off the device.
