2021-12-23, 13:54
Hi, i using the skin for Kodi Matrix.
But I guess I need some help.
Is it possible to change the items in the submenus?
I cannot find any option for this.
Just an option to clone the submenu.
Thanks in advance.
Ok, i found the option.
But I have another question. Is it possible to add a path to my Nas where the genre icons are located to use them.
Or can the skin only use add-ons for that?
Hm, can I delete the posts?
I found a good solution.
I just use the movie genre filmstrip addon.
Than I copied my pictures with the correct name in the folder and it works...
Thanks in advance.
