2021-12-27, 04:34
Hi there,
I often find myself needing to reboot LibreELEC, either because of a freeze, or because the only extension that do backups freezes well before reaching 100% (or when it does complete, slows LibreELEC to a crawl until restarted) (two or three hard reboots per watch session isn't unusual).
Issue is, if I reboot because of a freeze, usually TV stays on, and the bleeping sound effect right after the splash screen is ear-ripping (subjectively much louder than most movie soundtracks). Plus, it's rude for the neighbours, too.
The simplest solution would be to mute on boot, or at the very least, set it at a very low volume one startup. I don't wish to disable all effects, though. What is the proper way to achieve that?
