Full Version: lock the channels for adults
Hi Quartz is my favorite skin,
but there is one option that is missing and I can not find it anywhere on the menu, this is the option to lock the channels for adults, please if anyone knows where this option is let me know, Thanks in advance Image
(2021-12-29, 15:24)ramadan Wrote: [ -> ]Hi Quartz is my favorite skin,
I don't have an answer for you but I do know this question is not specific to any particular skin. Recommend you post your question in the PVR & Live TV Support forum. Good luck.
Hello and thanks for the answer, but I think the topic is right here, in this skin there is no such specific option, but in other skins there is this option, please see thisImage
Quite right. I will correct this oversight in a future release. In the meantime you can download the fix here. Just copy that file into the skin's 16x9 folder.
@ramadan - did the fix work for you?
Yes thank you very much for that, Thank you very much for the quick response
Thanks for the feedback. Thread marked solved.
