Full Version: <limit>15</limit> in smartplaylists
Reference:
/usr/share/kodi/addons/skin.estuary/playlists/unwatched_tvshows.xsp
/usr/share/kodi/addons/skin.estuary/playlists/unwatched_movies.xsp
Is the limit of maximum 15 in these 2 files enforced by the Estuary skin or by Kodi?
Why is there a hard limit of 15?
Have you tried changing the limit in the playlist file in your local install... https://github.com/xbmc/xbmc/blob/master...ies.xsp#L8
(2021-12-30, 22:16)Up Next ..... Wrote: [ -> ]Is the limit of maximum 15 in these 2 files enforced by the Estuary skin or by Kodi?
Neither really, they're set in the actual playlist itself -
Those are the files that I mention under reference in my first post.
When I changed the limit to anything higher than 15 (even just 16) only 15 shows/movies are displayed. That's why I opened the thread.
you need to edit in Includes_Home.xml
look for
target="$PARAM[widget_target]" limit="
<param name="widget_limit">
In file /usr/share/kodi/addons/skin.estuary/xml/Includes_Home.xml I found the following line. In which I changed limit="15", into limit="100".
xml:
<content sortby="$PARAM[sortby]" sortorder="$PARAM[sortorder]" target="$PARAM[widget_target]" limit="15">$PARAM[content_path]</content>
Then in file /usr/share/kodi/addons/skin.estuary/playlists/unwatched_tvshows.xsp I changed <limit>15</limit>, into <limit>25</limit>
That worked. Now 23 TV shows are showing up under Unwatched TV Shows. Thanks very much for helping out. All of you. And Happy New Year to all. All the best wishes.
EDIT: How do I mark this thread as solved?
(2021-12-31, 16:20)Up Next ..... Wrote: [ -> ]How do I mark this thread as solved?
Done it for you.
Cheers!
