Kodi was running last night now it won't start.
Reinstalled - Failed
uninstall, reboot, reinstall -Failed
No evidence of the app in Task Manager
Run As Admin - Failed
Windows 11. Home (22000.376)
16 GB RAM
Surface 8 Pro
Delete file 'guisettings.xml' in the
Userdata (wiki) folder and retry.
Not so much...I deleted the file and I saw the matrix screen for 1 second but that's all.
hastebin - gimumoxiqi (kodi.tv)
The link is above. This was very helpful. I did not realize I could actually get the log file.
Please post the full URL as-in the above, it would be
https://paste.kodi.tv/gimumoxiqi.kodi and turn on debug logging in settings>systems>logging - the short log doesn't impart enough information.
bacohen8 If you cannot navigate Kodi's GUI (crashes before you get chance), then please follow the instructions
here, using
example 1 as the code to put in the file. Once you have done that, try to start Kodi again and post a link to the new log file that will be created.
