2022-01-05, 11:43
I'm getting MySQL error notification and wanted to update MySQL on my Kodi box.
I've downloaded MySQL Installer and asked it to upgrade MySQL but the last step asks you to login as the root user. I have no idea what the password is for this. I have tried the usual admin, root and blank but no luck. Is there an config file somewhere where the password is stored or is there a way to retrieve it.
I have seen articles on resetting MySQL root password. But if i reset it Kodi will no longer be able to connect using the old password.
I've not been able to find any information on changing the Kodi data connection string should the password need resetting.
Can someone tell me how i can find the current Kodi MySQL Password or explain how i can change the password in Kodi if i need to change it in MySQL ?
Erick
Erick
