Full Version: Advanced Kodi Launcher - Game and Emulators frontend for Kodi
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
(2023-08-05, 00:41)VisionaiR Wrote: [ -> ]I just released an app to make it easier to start a game from Moonlight by using the appid as a parameter on android. It makes things easier to integrate AKL or IAGL to Moonlight
check it out here https://forum.kodi.tv/showthread.php?tid=374011
Nice work! But AKL already has Moonlight/Nvidia gamestream support. You can download and install the plugin for AKL and the only manual part is having a correct certificate for the pairing.
Have a look at the code at https://github.com/chrisism/script.akl.nvgamestream . Feel free to use/add here.
Although for the AKL plugin you only need the Moonlight/Sunshine/Nvidia Gamestream parts, there are many ways to do the server/PC side.
I myself use it with running Playnite on the PC. I dont start it through steam though, just directly Playnite. I have created a simple script plugin for Playnite that updates the Sunshine library each time the Playnite library gets updated, to keep it in sync.
The AKL plugin takes care of scanning the Sunshine library and adding all the games to AKL. The AKL plugin launcher automatically picks the corresponding entry for Moonlight and starts the client.
Have a look
(2023-07-27, 03:10)yawningapples1 Wrote: [ -> ]I'm trying to migrate from AEL but the Import Category/Launcher XML configuration file tool seems to be broken - it does not allow me to select one exported by AEL. As a test I also tried with one exported by AKL and it wouldn't let me either. Any workaround?
Did you use the xml files from within the addon_data directory of AEL? Those should work for the import.
Hi!
First of all, thanks for this great tool. I can't live without it!
I have a strange problem, I'm on kodi 20 on windows. When I try to launch a game in retroarch, all libretro cores work without problems except mame, that games don't start.
It's strange because in AEL works great, but in AKL is not working. Everything seems to be correct...
Would you have any idea to solve this problem?
Thanks a lot in advance!
(2023-08-07, 11:52)isgahe Wrote: [ -> ]Hi!
What is the MAME launcher configuration in AEL? Perhaps it uses some special retroarch property.
I don't think so... It's the same config as ael uses.
Retroarch.exe "path to mame core" -L "%rom%".
The strangest thing is that any other core runs great, even in AKL. Same config in AEL runs also great in mame.
I'm getting crazy but I can't find any clue to think I'm doing sth wrong... Confused
Hi and thanks for a great addon! When I have paired the gamestream plugin with my gaming PC, I get a prompt where I have to choose a client (moonlight-pc java or moonlight-chrome) what file should I choose here? I couldn't find any info anywhere on what to do at this step
thanks in advance
Hi.
  I use Kodi on Ubuntu linux.
But cant by any means start Supertuxkart from AKL.
Tried add Standalone ROM with external launcher many times, but no dice Smile
Can any say how to for stupid me?
I just installed this on my Nvidia Shield and I have absolutely no idea how to get this started.
The official guides for installation and setup are probably from from 1985. At least I don't see any options to setup collections, a hierarchy, ROM paths or anything that the wiki promises.
All I see when starting this add-on in Kodi is an overview that says
<Favourites>
[Most played ROMs]
[Recently played ROMs]
Browse by...
Global Reports
Utilities
All of these options lead to empty dead ends. None of them offer any options for me to setup anything.
I am most likely too dumb for this and there is no documentation whatsoever.
Hey there, curious if someone can help me use this app to launch Minecraft. For instance, let's say I have a shortcut to launch the game... how can I use Advanced Kodi Launcher to trigger the link from a menu item in Kodi?
