2022-04-30, 21:49
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
2022-04-30, 22:20
Could it be not displayed because the TV does not support HDR
2022-04-30, 23:02
Thanks for this skin. I'm running the Nexus version and it works well.
One request: Could you add the running time / time passed to the small Video OSD like it does on the full OSD? Currently it only shows the remaining time.
2022-05-01, 09:42
(2022-04-30, 22:20)crazyturk Wrote: [ -> ]Could it be not displayed because the TV does not support HDR
No, the HDR Flag is missing indeed on OSD. Will be fixed with next update. HDR property is reading from file, not from capability of device (TV).
2022-05-02, 10:47
(2022-04-30, 23:02)MrMagic Wrote: [ -> ]Could you add the running time / time passed to the small Video OSD like it does on the full OSD? Currently it only shows the remaining time.
With the next update there is an option to switch between current time/total time and remaining time in skin settings when using small OSD.
2022-05-03, 09:47
(2022-05-02, 10:47)_BJ1 Wrote: [ -> ]I came here to ask for the same thing about running time in small OSD. Thank you for that. Additionally, can you add "gear" for downloading/selecting subtitles to small OSD also, because sometimes, even if we have subtitles, we need to download a different one. Thanks!(2022-04-30, 23:02)MrMagic Wrote: [ -> ]Could you add the running time / time passed to the small Video OSD like it does on the full OSD? Currently it only shows the remaining time.
One other question I have is about vertical scroll bars in the library...how can I disable them? Is there an option for that in the skin or KODI options? I know I've seen it before in some skins. Maybe it IS here, but I just didn't find it.
Velimir
2022-05-03, 10:16
Quote:Additionally, can you add "gear" for downloading/selecting subtitles to small OSD also, because sometimes, even if we have subtitles, we need to download a different one.Don't use the simplified Video OSD. There is a subtitle setting (gear) in the small OSD too.
Quote:One other question I have is about vertical scroll bars in the library...how can I disable them? Is there an option for that in the skin or KODI options? I know I've seen it before in some skins. Maybe it IS here, but I just didn't find it.There is no option for disabling scrollbars - and as they are part of the navigation structure of the skin it is not possible to remove (or disable) them from skin. This would result in a complete rebuild of the skin.
2022-05-06, 08:51
Update 4.0.0+nexus.4
Update 3.4.0+matrix.14
- add missing hdr type flag in video OSD
- Settings option for displaying current time/total time and time remaining in small video OSD
- changing fanart, many thanks to samfisher (Team-Kodi)
- File view in video widgets added (movie, tvshow)
- moving hdr+ detection priority above hdr detection
2022-05-08, 22:27
2022-05-08, 23:26
(2022-05-06, 08:51)_BJ1 Wrote: [ -> ]Update 4.0.0+nexus.4File view in video widgets added (movie, tvshow) : cannot find out what this is. Can you explain plse (perhaps screenshot makes it clear). Tnx.
2022-05-08, 23:44
2022-05-09, 10:53
@crazyturk HDR detection on live streams (PVR) seems not supported atm. I couldn't really test this as I'm not able to receive 4K (HDR) live channels. I've opened an issue on Kodi bugtracker: https://github.com/xbmc/xbmc/issues/21383
2022-05-10, 22:44
Yes, after live TV registration, HLG and HDR symbols appear in my post -registration play.It does not appear in normal broadcast.
2022-05-10, 23:02
2022-05-13, 22:18
### 3.4.1+matrix / 4.0.1+nexus ###
- improved and freshed up Channel Guide OSD, Channel OSD
- missing HDR label on Live-TV (PVR) added (Nexus only) - but still missed due an issue
- Record flag added
