Full Version: Estuary MOD V2 Matrix/Nexus/Omega KN Edition
The channeld osd art doesn’t change when zapping through channels.
Works as espected here. Maybe you have to update the PVR Artwork Module. Actual version is 2.1.9
If artwork is provided by epg it works ok, but if you change on a channel that have fanart downloaded from internet it will get stucked on that.
How do you change the MPAA rating to show up as "PG-13" instead of just "13"? I restarted Kodi and it kept showing up this way
Detection of PG-13 is done by "Rated PG-13". Look into the record and make sure the rating entry is set to "Rated PG-13". You can use the "Metadata Editor" addon for that.
Running latest Kodi (in dutch language) and Estuary Mod on PC. I have a strange behaviour. Going into skin settings/home/widgets, I cannot change the default action on Movie and TVShow widgets. Clicking on this item doesn't change the action (it does nothing). It stays even in english (show info) although my language is dutch. Strange enough, on my second device (intel nuc, same setup), I do can change the action (toon informatie or afspelen). I guess it has something to do with the language. Do you have a hint how I can fix this ? Tnx
That's an old bug in the switching subroutine of the skin. Switch back to english, choose the new setting of this option (this should be changeable now) and switch back to your desired language. The second way is to delete the entry
xml:
<setting id="widget_action" ...>
in the settings.xml (.kodi/userdata/addon_data/skin.estuary.modv2/settings.xml) of the skin.
If I have more time to do this I will fix this behaviour later Wink
Tnx. I will wait for your fix.
### 3.4.1+matrix.1 / 4.0.1+nexus.1 ###
  • ​use sort order of upcoming next episodes from embuary skinhelper addon
  • move decorator background of video preview from epg window into background
  • Fix bug on skin settings is unchangeable if a setting met no language string when language has changed.
Would it be possible to add Skin Helper Service widgets to PVR? To enable the use of artwork in last played channels instead of channel logo, and have the option to use Poster or Landscape view for all the widgets
Skin Helper Service has been removed from this skin and won't reimplemented. Switching between poster or landscape view requires a extensive rebuild of the skin and is not possible. Sorry for that.
No worries, thanks for your great work!
### 3.4.1+matrix.2 / 4.0.1+nexus.2 ###
  • Improved OSD animations (reduce flickering slides)
  • Icon Powerdown/Timer added (active addon "Recording & Power Manager - RPM")
  • OSD PVR flag added if broadcast is available in local file system
  • Background for PVR channel icons added
Hey there. I’m getting some warnings in the log that appear to be related to this skin. This one pops up all the time:
WARNING <general>: CPythonInvoker(17, /storage/.kodi/addons/script.skinshortcuts/resources/lib/entry_point.py): the python script "/storage/.kodi/addons/script.skinshortcuts/resources/lib/entry_point.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6WindowE,N9XBMCAddon9xbmcaddon5AddonE
There are others as well, though. Anyone have any ideas? It’d be a shame if I had to uninstall this skin, because I really love it so far.
I’m running the latest stable coreelec/kodi 19.4 and est mod v2 3.4.1 on an Odroid n2+.
Log: https://paste.kodi.tv/ihiledofap
You can ignore this warnings from skinshortcuts. They also appear on other skins if them using skinshortcuts too.
