(2022-08-17, 20:50)_BJ1 Wrote: [ -> ]### 3.4.2+matrix.1 / 4.0.2+nexus.1 ###- Transparency of label background of widgets (Flix view) customizable
- semitransparent Background for plot in video info added
- Overlay texture in Flix view changed
- fix wrong behaviour on info button if a movie is paused
- reorder language ids above 40xxx to 31xxx and usages to fit within the recommended range for skins
For personal reasons, this is the last update for a longer period of time. Be patient, I'll be back
thanks, will wait here :-)
Hi there,
seems like in current matrix branch of this mod there are some labels missing (tested on both libreelec and pc versions of Kodi 19.4.Matrix with actual skin version, fresh install, all recommended addons installed).
Those are missing when you customize your home screen an want to add custom widgets:
First when you want to define the type of widgets
Next, when you blindly have selected the 3rd option
And finally if you want to select the widget appearance
Can someone tell me the labels that are missing here (in 3rd pic im pretty sure 1st world is POSTER) and where i can add them?
(BTW this is also the case in the Nexus version of this skin)
This happens because some labels has changed their range from above 40xxx to a lower value and these seems to be overseen. Will be fixed in few weeks. ATM I'm Not available.
Ok. Good to know i've done nothing wrong on my side
(2022-01-14, 19:41)_BJ1 Wrote: [ -> ]You need an OMDB API key and have to prefer the Universal Movie Scraper as the standard scraper for your movie database.
Sorry for the dumb question but how can I “prefer” the Universal Movie Scraper for my database?
TMDB TV Shows. Enable fanart.tv within the scraper settings.
Did I break something, or did the latest update stop TV Show thumbnails from showing in the wall/infowall (poster) views?
The widget view still works, mind.
