Full Version: Estuary MOD V2 Matrix/Nexus/Omega KN Edition
(2022-10-21, 22:13)stagezin Wrote: [ -> ]- official skin have more power options, and since I use CoreELEC, I would love to have option for reboot to android (on this image you can see it under reboot from eMMC/NAND). Is it possible to include all this option in one of your future updates?
This has already done for a long time. Just enable "show extended power menu" (Skin Settings -> Extras). The screenshot below (sorry - german) is from an Android device (S905x3 - Tanix TX3).
Quote:- Other thing is regarding movie view/list mode. My design complain is about placement of cd, which is on bottom of poster. Very ofter movie title is in that part of poster, and cd goes over it, and title is not seen. Do you thing that cd can be placed over poster, in top part, maybe even not to be seen completely, maybe half of it, just to come beyond poster, so we can see half of cd?
Hmm, I don't agree with that. Even though cd art covers the poster, most of the movie titles are visible too on cd art - so that's not a big handicap. See screenshots. Half of a cd behind the poster takes up too much space.
Fantastic. Great. Did not see that option there. Thanx!
(2022-10-22, 12:24)_BJ1 Wrote: [ -> ]Hmm, I don't agree with that. Even though cd art covers the poster, most of the movie titles are visible too on cd art - so that's not a big handicap. See screenshots. Half of a cd behind the poster takes up too much space.
I didn't mean widgets. They're fine. I mean when you enter movie library. I can'tmake screenshot now, but its view with 3 parts... left is logo, genre and synopsis, in the middle is list of movies in and on the right is part I'm talking about, large poster and cd on the bottom.
I think its better to move cd on top, and behind poster, or maybe you can make to be choosed, we can choose, top, top below (half visibile) and bottom, as it is now.
If You take a look to the view selection, You see that all visible cd art on the bottom of the covers/posters - for all views. I don't change this, not even for a single view. Have made some adjustments instead.
I used the skin for a long time, as it had a couple of really key features.
Was simple like the default skin, but had ability to add nodes, with sub nodes, and to apply filters to them.
So I can have a menu option called Music Documentaries, which would bring up only those titles, or a menu called Documentaries, which would have say 5 options underneath; nature, music, history, woodworking, other.
Also, the info screens were much better, and things like MPAA ratings etc showing were really good.
I stopped updating kodi/LibreElec after I spent a year putting this all together and then found it was unsupported.  I just left a working/running system for the family to use.
Thanks to you I now have updates, and have even more options, so thank you, Danke, Vielen Dank...  Do you have a donate button so I can buy you a beer?
Tchuss, Dave
Thank you very much for the kind words.
### 3.4.2+matrix.8 / 4.0.2+nexus.8 ###
  • Hungarian language update
  • Font fix of Economica font family
  • PVR OSD: Introducing last five channel switch (optional)
  • smaller fixes
  • add missing studio logos on several widget layouts
Image[/url]
BTW: I noticed that in your flags you use for example mpeg2.png, however a lot of files I have, and have seen, will have meta data mpeg-2, so there will be no match.
Looking in the textures file, it feels like an obvious (if rather hacky) solution, is to remove any dash/hyphen from codec param, before fetching the texture.
Just an idea.
I'll double the file mpeg2.png to mpeg-2.png in the texture file, that should match the meta data. Also doing this for mpeg-1.
I just wondered if it might come up on other cases, and stripping hyphens covers them all - but I guess it's not that common!
A skin doesn't know about string operations like substitutions, only comparative methods are possible: https://kodi.wiki/view/List_of_boolean_c...ons#String Almost skinners use a contruct like
<texture>$INFO[ListItem.VideoCodec,path/to/folder/,.png]</texture> for determining the right flag/label. See ListItem.VidoCodec for usual used codecs: https://kodi.wiki/view/InfoLabels#ListItem
(2022-10-25, 08:41)_BJ1 Wrote: [ -> ]### 3.4.2+matrix.8 / 4.0.2+nexus.8 ###
  • smaller fixes
Image[/url]
The last five channels switch is a really nice addition, thanks!
I can't find the menu "play speed",when i play the video .
Firstly a big thank you for keeping the Estuary Mod alive and your continued work on - it's fantastic.
Around the 3.4.2+matrix.6 update the video progress bar now has a larger white block for the current position marker - it used to just be a simple vertical line (just like the seek marker).
A small request, is it possible to get an option to remove this white block and just go back to the progress bar from previous versions please?
I did try toggling the settings for "simple seekbar" but it didn't seem to make any difference to this, so thought I would ask just in case there was something I am missing.
Thanks either way!
I have the skin installed on Windows PC and Android Box, Media Flags color is set as skin default on both, but the color is white for all flags in Android, while it has different colors for each flag in Windows, any reason for that? and how can I replicate the same in Android?
