@psbguy Goto Interface -> Skin -> Theme -> Color Already done. To late for me today.
Don't know why this behaviour is on your Android box. On my box all flags ar coloured if I choose the color theme.
(2022-10-26, 19:13)_BJ1 Wrote: [ -> ]@psbguy Goto Interface -> Skin -> Theme -> Color Already done. To late for me today.
My bad! I didn't pick the color theme in Android box, now it's working, thanks!
nullafy I couldn't revert all changed code to bring back the seek marker completely. There are 600 -700 lines of code changes for introducing the simple seekbar.
(2022-10-26, 11:58)nullafy Wrote: [ -> ]Firstly a big thank you for keeping the Estuary Mod alive and your continued work on - it's fantastic.
Around the 3.4.2+matrix.6 update the video progress bar now has a larger white block for the current position marker - it used to just be a simple vertical line (just like the seek marker).
A small request, is it possible to get an option to remove this white block and just go back to the progress bar from previous versions please?
I did try toggling the settings for "simple seekbar" but it didn't seem to make any difference to this, so thought I would ask just in case there was something I am missing.
Thanks either way!
Yes, I dont like it too.. Really annoying I have removed immediately from my personal copy, when I first see in the skin. But that was long time ago, dont remember from whitch lines have I deleted, the marker image path, from the codes.... I will trying to search in my pc..
Replace all occurences of osd/progress/nub_leftright.png
in Includes.xml
with osd/progress/nub_bar.png
. That should do the trick.
(2022-10-27, 09:46)_BJ1 Wrote: [ -> ]Replace all occurences of osd/progress/nub_leftright.png
in Includes.xml
I just tested your suggestion and can confirm it works for the most part - instead it now has a smaller white "nub" at the current position which isn't all that bad!
Thank you for the suggestion =)
Have push an update of the skin mod to github (not in the repo yet) with an improved seek bar/video osd. Maybe this better suits your needs.
How does one stop fanart from being used in the background on every page in the library? I am sure there used to be a setting, but danged if I can find it. Thanks!
"Show media fanart as background"
(2022-10-31, 22:16)_BJ1 Wrote: [ -> ]"Show media fanart as background"
Setting set to off
Artwork still appears....
Ah yes. This settings has affect only to the home screen, not for the different views within the libraries. A possible solution is setting the "opacity for fanart as background" to 0. You'll find this option in Skin Settings --> Colors.
(2022-11-04, 16:29)_BJ1 Wrote: [ -> ]Ah yes. This settings has affect only to the home screen, not for the different views within the libraries. A possible solution is setting the "opacity for fanart as background" to 0. You'll find this option in Skin Settings --> Colors.
Yup, that works great. There was a setting to do this before though, as my last 3 builds didn't have this, and it wasn't implemented like this. But, it works, so I'm good. Thanks again!
3.4.2+matrix.9 / 4.0.2+nexus.9- add "play trailer" to contextmenu
- fix unmatched parentheses in Home.xml (Nexus only)
- fix doubled background in flix view
- fix position and size of context menu in flix view
- last seen movie template added (reset/modify main menu required)
- seek bar components modified
(2022-10-10, 18:13)_BJ1 Wrote: [ -> ]### 3.4.2+matrix.5 / 4.0.2+nexus.5 ###
How do I enable titles of the episodes underneath thumbnails, like in above? But for Movies & TV Shows. I've been going through options banging my head and can't find anything related to this. I'm on Matrix, If it matters. What am I missing?
Would really love to enable titles underneath thumbnails for TV Shows & Movie related media.
Scroll down to Widgets in Home Menu
