Would it be possible to add the option for "PVR" widgets to show info as a default action similar to "Movies" and "TV Shows"?
Sorry, that's not possible. The PVR widgets using a content path for playing media (channels) and therefore there isn't a costumable click event.
Found another way
(2022-12-22, 17:59)_BJ1 Wrote: [ -> ]
Merry Christmas !
It looks like the link to the red button, Download Repo Addon is down. I've tried several times tonight.
I thought I could paste some screen captures, but that option is not available.
I really like this skin over estuary, as it gives more control and contrary to estuary, doesn't have PVR channel/title info scattered all over the screen. Nice and neat!
I have what i guess would be a couple of FR as i dont see a setting for these:
- Could we have expire dates exposed for the recordings window ? I kind of miss this info
- Could we have a setting to _not_ display the 1/3 screen filling info when skipping back or forward ?
Thanks for maintaining this skin, excellent work !
Atreyu
(2022-12-26, 09:59)Atreyu Wrote: [ -> ]- Could we have expire dates exposed for the recordings window ? I kind of miss this info
There isn't a label to display a expire date:
https://kodi.wiki/view/InfoLabels#PVR - sorry
Quote:- Could we have a setting to _not_ display the 1/3 screen filling info when skipping back or forward ?
Yes, set the option "Use simple Seekbar on Chapter and Time Seeking". Additional you can set "Use small Video OSD" and/or "Use simplified Video OSD Navigation". This options you'll find in "Video OSD" of the Skin-Settings.
Hm, default estuary does show expire dates, so i thought it should be possible. Too bad.
I'll have a look at the videoOSD settings again as i did not seem to get the desired results before doing exactly what you describe. Must have missed something there.
(2022-12-26, 10:53)Atreyu Wrote: [ -> ]Hm, default estuary does show expire dates, so i thought it should be possible. Too bad.
What is expire date? Do you mean the last date before a recording is going to delete automatically (e.g. lifetime)?
(2022-12-26, 11:10)_BJ1 Wrote: [ -> ]What is expire date? Do you mean the last date before a recording is going to delete automatically (e.g. lifetime)?
Correct.
Hmm I've just switched back to default Estuary and checked my recordings. I don't see any expiration dates in none of the menus or widgets. Could you provide a screenshot?
Unfortunately,not right now as i am celebrating Xmas (out of town).
But i can say i use TVheadend if that matters and it was called 'expire date' in the gui iirc.
Section is 'recordings', and it only shows for recordings that have been recorded with an expire value set. Very handy feature.
Ah ok, as I'm using TVHeadend too, expiration date is set to infinite in my setup.
I thought that might be the case
So it may be possible to have this incorporated in this skin ..?
(2022-12-26, 11:55)_BJ1 Wrote: [ -> ]Ah ok, as I'm using TVHeadend too, expiration date is set to infinite in my setup.
Yes, I’m so glad to see this skin/mod is brought back to life! 😍
Have been using this in the past but stopped because it wasn’t supported anymore. Luckily I stumbled upon this thread 😃
