My kodi says there's an update for 19.5 version. Can I update without loosing everything?
Awesome. That would make this skin near-perfect for my use
(2022-12-26, 14:15)_BJ1 Wrote: [ -> ]@Atreyu Yes.
Should be no problem between the same major versions.
(2022-12-26, 14:27)oliviergregoire Wrote: [ -> ]My kodi says there's an update for 19.5 version. Can I update without loosing everything?
(2022-12-26, 09:59)Atreyu Wrote: [ -> ]- Could we have a setting to _not_ display the 1/3 screen filling info
Works with the 'simple seekbar..' setting enabled.
This was actually the first thing I tried before. I must be sobering up :-D
Thanks, PVR widgets works pretty well!
Thanks for adding expire dates for recordings. Much appreciated!
(2022-12-29, 00:33)Atreyu Wrote: [ -> ]Thanks for adding expire dates for recordings. Much appreciated!
Just strange that this info label is not documented in the wiki...
is there any way to install christmas themes permanently? because my kids love this! please help! please
I agree, wiki's are known to be behind development sometimes. I can imagine documenting is not always the fun part
(2022-12-29, 02:01)_BJ1 Wrote: [ -> ] (2022-12-29, 00:33)Atreyu Wrote: [ -> ]Thanks for adding expire dates for recordings. Much appreciated!
(2022-12-29, 05:11)Datntien Wrote: [ -> ]is there any way to install christmas themes permanently? because my kids love this! please help! please
Really? They don't want to see the Valentines, Easter and Halloween themes anymore?
Is there a way to get actors list and ratings on movie information page without using the local library? I'm using trakt lists to show tv shows and music. Estuary default skin shows actors. Thanks!
As Umbrella and Fen are on the list of banned addons (see
https://kodi.wiki/view/Official:Forum_ru..._blacklist) I'm not willing to support these addons. Nevertheless I will take a look to the differences between the handling of the actors list in plain Estuary and the Mod and maybe updating the code for this.
In my main menu, I have added my Trakt watchlist (through TMDBH). As you can see, the ratings on top of the poster of each movie are the ratings from TMDB. Is it possible to display the ratings from IMDB instead of TMDB ?
The movies, added in my library, have indeed the IMDB ratings displayed (std ratings in Universal Movie Scraper are set to IMDB). Would be nice if the ratings in my Trakt watchlist are also the IMDB ratings (or perhaps next to the TMDB rating). I know I can access the ratings in Embuary Info Script, but this is not so handy. Tnx.
https://imgur.com/1P3cLFZ
