I’m having troubles downloading the repo on firestick, is it possible? Also the “download repo addon” isn’t loading the file for me even on my browser not sure why
Try the webdav method:
- open file manager in Kodi
- add source
- search
- add network: protocol WebDav-Server (HTTPS) or Webserver (HTTPS), address repo.kodinerds.net, remote path: webdav
- name of webdav source could be anything
Then:
- Install from Zip
- navigate to your webdav source
- install
Some screenshots are availabe here (sorry, german):
https://www.kodinerds.net/index.php/Thre...post606076
Yes thank you so much, your instructions were clear enough and I was able to finally download.
3.4.2+matrix.18 / 4.0.2+nexus.18
- hungarian language updated
- flixview improvements (background for sets, movie sets poster)
- run condition of pvr artwork module for pvr nextup fixed
Hello, first of all I want to thank you very much for the Estuaire ModV2 skin.
However, since about 3 months, I have a problem in the TV Series category only in the TV category Widget.
I have the name of the TV series that appear twice.
I registered to report the problem, because despite the updates of the skin the problem persists.
I redid a new installation with Kodi 20 Nexus, and the problem is still there.
I am sorry for my English language, because I am French.
Thanks a lot for your help.
Yes I forgot, I have another problem with Kodi 20 Nexus
I also have a problem with the user interface adjusting the overscan when I use the Skin.
When I put the original skin back on, the user interface that adjusts overscan works.
Thanks for your answer.
You don't need to adjust the overscan on modern TVs except you have an old Tube-TV. Nearly every TV with HDMI input is able to fit the whole screen within. It's just depends from screen format setting of the tv. Don't use 16:9, wide or similar on your TV, use "just scan", "compute" or else depending on your TV.
I have a recent Samsung 4K HDR+ TV, yet I needed to set the Kodi interface after a new installation, sometimes I also need to set the first time for each frequency in playback, 23,98, 25, 50 fps ect.......
But it's not too bad because I solved my problem by putting back the default skin just for settings, then I switch to Estuary Mod V2 and everything is fine.
Thank you.
(2023-01-21, 15:36)Nexusof9 Wrote: [ -> ]I needed to set the Kodi interface after a new installation, sometimes I also need to set the first time for each frequency in playback, 23,98, 25, 50 fps ect.......
And even this is not required if You choose the right setting within your tv display options
I remember this setting is named "just scan" on Samsung TVs.
I also use the setting to align the position of the subtitles, now with the new subtitle support, with the manual setting I also have to adjust the position bar to the desired height.
But it doesn't matter if with the Skin it doesn't work.
because as I report I found the solution to make the settings of my TV under the original skin.
Thanks for the information
On my side, I found the solution.
I posted for just I pointed out that the skin does not support this setting as the original skin.
(2023-01-21, 13:16)Nexusof9 Wrote: [ -> ]I have the name of the TV series that appear twice.
Has been fixed and will be available with the next update.
Thx
Thank you very much for all your work.
Again a huge thank you for your Estuary Mod V2 skin, I am a big fan and it is really fantastic.
