(2023-04-28, 19:52)_BJ1 Wrote: [ -> ]@dapharsyde Could you check if the overlapping label issue still exists? I don't have any tv-broadcast with chaptermarks available...
Overlapping issue is fixed. Looks like the chapters are no longer displayed at all, which isn't that big of a deal for live TV (via Hulu plugin). Assuming that was your intention, the issue appears to be fixed, thanks!
I've decided to hide the chapters in such constellations. Thanks for reply.
Hello Everyone,
Just installed this skin and liking it very much. One small question:
If I select Info for say a Movie, select an cast member in the movie I get a pop-up window like this:
If then must select Extended Info to find details of this person. Is it possible to go straight to Extended Info upon selecting the cast member?
TIA
Hi again,
Another question. The Add-ons have no label like this:
Can I have labels like the standard Estuary Skin:
(2023-05-03, 07:20)gregeeh Wrote: [ -> ]Is it possible to go straight to Extended Info upon selecting the cast member?
Not possible. In that way you'll never get the filmography from the local database.
Thanks for both answers, really appreciated.
(2023-05-04, 00:51)gregeeh Wrote: [ -> ]EDIT: I had to disable this setting to get the labels.
Yes. That's I've wrote there. Deselect is the same as disable for me
Hi all,
I suppose there is no way to make the photo widget thumbnail fill the complete widget. Note the border around the thumbnail (just a red JPG in this case).
Hello.
Is it possible to have fanart in main information screen for a movie instead in the extra one? As in the old versions of the MOD.
Quote:Is it possible to have fanart in main information screen for a movie instead in the extra one?
No. For movie fanart use the extended Info window.
Quote:Is there a way to use the default KODI information page for movies and TV shows with this skin? Thanks
Your linked images are corrupt. And no, not possible. Use default Estuary instead.
FYI, the linked images aren't corrupt, but TeamKodi simply doesn't allow hotlinking images directly from our wiki.
If you copy/paste the URL manually into a new tab of your browser, the link will work.
