I'm not familiar with Pre Show Experience. I think that the addon needs a skin integration? Are there some guides for that?
My understanding is that it is a direct replacement for Cinemavision. Any XML files that have “Cinemavision” needs to be replaced with “preshowexperience”.
Also, I believe there is discussion about integration on the activity threads on the website I called out above.
Hi there, been enjoying this skin for a while, and finally time to update from Leia...
I am trying on a virtualbox install of LibreElec and I am getting an error installing from the repo.
I installed all the dependencies one at a time first (as I have had an issue solved that way before with Modv2) and they all installed fine, just this one didn't
I checked in the logs and the error is
error <general>: Copy - Failed write to file special://home/addons/packages/skin.estuary.modv2-4.1.2 nexus.4.zip
Before I post a whole log file, just wondered if there was any known issue with that, as I say, everything else installed fine, as did other addons from the same repo.
Thanks! Dave
Just repeat the installation from Nerdsrepo. For some reason the download fails sometimes.
I have tried it 30 times or so... same error every time
hslansky The integration of PreShow Experience has been done and is on github now. A regular update of the skin via repo appears next week...
I think it might be something to do with running it on virtualbox - I believe I was running in some sort of "run from this USB stick" mode, which didn't have enough space.. so it's not related to MODv2. Sorry for the inconvenience!
Anyone else having issue with notifications popup not appearing? Using Kodi 19.
Thank you
I have Matrix version 19.5 and the MPAA ratings aren't showing the same way they're displayed in the NFO files. For examples, for two movies, one is rated PG-13 and the other rated R, Kodi is showing the ratings as 13 and NR. Is there any way to have this skin display these correctly?
disregard above post. needed to add "Rated" to the NFO files
Kodi reads from NFO and store these values into the database. If you want to check some database values, open the Editor in video info and verify your values:
