2022-03-11, 04:22
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
2022-03-11, 04:36
second part
<visible>Control.HasFocus(5552)</visible>
<control type="label">
<width>700</width>
<height>35</height>
<aligny>bottom</aligny>
<label>$INFO[Player.Process(amlogic.displaymode),[COLOR button_focus]$LOCALIZE[32100]Displaymode : [COLOR white],[/COLOR]]</label>
<font>font12</font>
<shadowcolor>black</shadowcolor>
<textcolor>$VAR[SkinColorVar]</textcolor>
</control>
<width>700</width>
<height>35</height>
<label>$INFO[Player.Process(amlogic.eoft_gamut),[COLOR button_focus]$LOCALIZE[32101]Eoft_Gamut : [COLOR white],[/COLOR]]</label>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<label>$INFO[system.memory(total),[COLOR button_focus]System Memory : [COLOR white],[/COLOR]]</label>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<label>$INFO[System.CpuFrequency,[COLOR button_focus]$LOCALIZE[13284] [COLOR white],[/COLOR]]</label>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<label>$INFO[System.GPUTemperature,[COLOR button_focus]$LOCALIZE[22010] [COLOR white],[/COLOR]]</label>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<label>$INFO[System.CPUTemperature,[COLOR button_focus]$LOCALIZE[22011] [COLOR white],[/COLOR]]</label>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<font>font12</font>
</control>
<width>700</width>
<height>35</height>
<font>font12</font>
</control>
2022-03-11, 11:13
I'm wondering where you get the info labels Player.Process(amlogc.displaymode) and Player.Process(amlogic.eoft_gamut)? I don't find them in official Kodi Wiki: https://kodi.wiki/view/InfoLabels#Player_labels
Btw. these labels are not available on x86 systems, but got it.
2022-03-11, 14:28
### 3.4.0+matrix.7 ###
- Remove dependencies of Embuary Helper/Script from addon.xml
- Add dependencies of Embuary Helper/Script to "needed Addons" in skin settings
- Fixes on PVR channel status visibility and media menu in several channel views
- Player process info extended (thanks to crazyturk who pointed this out)
2022-03-12, 18:30
2022-03-12, 18:51
Hi @_BJ1, how can i get rid of these errors?
Quote:2022-03-12 18:42:44.093 T:15996 INFO <general>: Loading skin file: DialogVideoInfo.xml, load type: KEEP_IN_MEMORY
2022-03-12 18:42:44.118 T:20856 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting G:\Movies\A.Knights.Tale.2001\\extrafanart\
2022-03-12 18:42:51.459 T:18292 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting G:\Movies\A.Star.Is.Born.2018\\extrafanart\
2022-03-12 18:42:54.511 T:13508 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting G:\Movies\A.Walk.to.Remember.2002\\extrafanart\
2022-03-12 18:42:57.159 T:20764 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting G:\Movies\A.X.L.2018\\extrafanart\
2022-03-12, 19:56
2022-03-12, 20:08
I see. I dont have extrafanart folders so i wonder if i can disable extrafanart option. If exist such option
2022-03-12, 20:48
The error message was not generated by the skin even if the info entry was on top of the errors. DialogVideoInfo.xml only loads infos from one movie/tv show/etc, not from a bunch of movies.
2022-03-12, 21:39
I tried to isolate the error and i disabled all video addons, but the error persists even then. On standard estuary, i didnt saw it. On both devices (windows and OSMC) i saw it after i installed Estuary mod v2, couple of days ago. I even put an fanart key on ”python movie scrapper”, but no luck
Maybe i need to install some optional addons? From your list i have installed only these:
- Skin Helper Service Color Picker 2.0.1
- Youtube
- Movie Genres Icon for estuary Mod v2
- Studio icons White 0.028
All are up to date.
Those error comes with the next ones. On both devices. Maybe are related
Anyway, if it cannot be fixed, and if it does not affect anything then it doesn't bother me.
I want to bring to your attention another thing that I saw, this time, in the log on OSMC
I'm sorry to bother you with these problems, but I really like estuary mod v2 skin, and I would like to continue using it if I can get rid of these troubles.
Thanks a lot for everything.
Oh, i forgot to mention, the ”ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting G:\Movies\A.Walk.to.Remember.2002\\extrafanart\” errors apears only when i press ”I” (Info) on remote on every move from library.
- Youtube
All are up to date.
Quote:2022-03-12 14:32:12.749 T:8361 ERROR <general>: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/3/39e31d3f.jpgOn Interface/Music OSD i see an option called ”Enable Extrafanarts for background”, but i dont have it ON because i dont have installed the ”Artist Slideshow” addon. But in Video OSD, there is no such an option. I dont know if its related or not, just a thought that crossed my mind.
2022-03-12 14:32:13.049 T:8361 ERROR <general>: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/8/8198a2bc.jpg
2022-03-12 14:32:13.455 T:8361 ERROR <general>: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/8/83da8c46.jpg
2022-03-12 14:32:13.520 T:8902 INFO <general>: CPythonInvoker(58, /home/osmc/.kodi/addons/script.embuary.helper/plugin.py): script successfully run
2022-03-12 14:32:13.522 T:8448 ERROR <general>: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/c/c1259c59.jpg
2022-03-12 14:32:13.822 T:8360 ERROR <general>: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/a/ad27171f.jpg
Quote:2022-03-12 14:35:05.813 T:9820 INFO <general>: initializing python engine.When this happens, the temperature of the Vero 4K jumps from 70 to 85+ degrees Celsius and the device runs very slowly. Maybe you have an ideea what to do in this case.
2022-03-12 14:35:06.247 T:9808 INFO <general>: CPythonInvoker(77, /home/osmc/.kodi/addons/script.embuary.helper/plugin.py): script successfully run
2022-03-12 14:35:07.622 T:9808 INFO <general>: Python interpreter stopped
2022-03-12 14:35:09.765 T:9820 INFO <general>: CPythonInvoker(78, /home/osmc/.kodi/addons/script.embuary.helper/plugin.py): script successfully run
2022-03-12 14:35:10.072 T:9835 INFO <general>: initializing python engine.
2022-03-12 14:35:11.125 T:9820 INFO <general>: Python interpreter stopped
2022-03-12 14:35:13.698 T:9835 INFO <general>: CPythonInvoker(79, /home/osmc/.kodi/addons/script.skinshortcuts/resources/lib/entry_point.py): script successfully run
2022-03-12 14:35:15.117 T:9835 WARNING <general>: CPythonInvoker(79, /home/osmc/.kodi/addons/script.skinshortcuts/resources/lib/entry_point.py): the python script "/home/osmc/.kodi/addons/script.skinshortcuts/resources/lib/entry_point.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6WindowE,N9XBMCAddon9xbmcaddon5AddonE
2022-03-12 14:35:15.118 T:9835 INFO <general>: Python interpreter stopped
Quote:The error message was not generated by the skin even if the info entry was on top of the errors. DialogVideoInfo.xml only loads infos from one movie/tv show/etc, not from a bunch of movies.
2022-03-12, 22:25
I've dived deeper into this problem and found a condition (variable) that try to access the content of an extrafanart folder: https://github.com/b-jesch/skin.estuary....1900-L1904. This variable is used by the info window for movies, tvshows and music showing extrafanarts. After commented out this variable the error has gone. I have to say that I take over the skin from Guilouz last year and I'm not completely familiar with the code yet. Sorry for that. I have now to decide which solution is the best for those who have an extra fanart folder and those want to display artwork from this.
2022-03-12, 22:42
Im glad you found the culprit
So, until you find the best solution for this, its ok for me to delete those 5 lines?
2022-03-12, 22:50
No. Delete these lines for video info: https://github.com/b-jesch/skin.estuary....#L624-L641
and this for music info: https://github.com/b-jesch/skin.estuary....#L464-L481
The reason behind that is the variable will never be called if the code from above is removed. Otherwise you have a call to an undefined variable.
2022-03-12, 23:12
Ok, i did it. Everything seems fine now with extrafanart.
Thanks a lot for your quick response and help.
