Full Version: Estuary MOD V2 Matrix/Nexus/Omega KN Edition
Cant find that option on omega, can you be more specific on whats needed to make it show up?
Having a problem with the Nexus version for a week or so now, using the skin causes Kodi to crash on boot.
Fatal Python error: PyImport_AppendInittab: PyImport_AppendInittab() may not be called after Py_Initialize()
I've tracked down other reports of this issue, linked to python version changes between 20 and 21.
https://github.com/xbmc/xbmc/issues/24069
Removing the skin solves the problem, but I'd rather not!
The issue you've listed above has closed because Nexus is out of support. There's nothing I can do now. Sorry. Best way seems to update to Omega.
(2024-07-01, 21:31)_BJ1 Wrote: [ -> ]Do you control the volume via TV remote (eARC)? Move up the Volume of the Nokia box with the Nokia remote ore use the kodi remote app.
I tried all remotes, TV, MediaPlayer, and receiver. None of them helped, not even after a factory reset of both TV and receiver.
Next step is factory reset the media Player and re-instal (arrrrrgggg...... hours/days of work)
(2024-07-01, 22:41)crazyturk Wrote: [ -> ]You can increase the volume from the sound amplifier in Kodi sound settings.
Yep I found that settings, (it is already on 100)
There's also a setting to change the "RePlay Gain" to make it louder, but it gives a possible problem of "clipping".
But I'll try that first.
EDIT:
Don't know what fixed exactly it but enabling all sound options options under (System -> Audio) Audio PassThrough,
And under Menu -> Player -> Music -> Volume Adjustment     set this on OFF/DISABLED (so no ReplayGain options anymore)
now it suddenly goes as loud as it was before...... finally!!! Now I can finally play a favorite track at highest volume. (Neighbours; sorry but won't do that too often  Cool )
### 4.2.1+nexus ###
  • End of development - Skin ist set as deprecated
  • smaller improvements in touch mode
  • special audio flags in info dialog fixed
### 21.2.1+omega.1 ###
hi _BJ1 - if it's not too much work for you, is it possible to get the YEAR of movie/tv show after the title in the OSD? thanks for your consideration.
This has already be done for some time - just enable "show year behind title" (or similar) in skin settings -> library...
### 21.2.1+omega.2 ###
  • Info labels to player process info added
  • Visibility condition of items in media menu side blade fixed (PVR, EPG)
  • Visibility of "Browse" item in home widgets are now conditional
  • HDRplus detection by filename added
Thanks again for your continued efforts
Question: If I update my Kodi from Nexus to Omega, will this be updated at the same time ans all my settings be kept?
Yes.
Hi @_BJ1.
1: When I select custom movie widgets, vertical panel 1 item (main menu auto hide) and active show media names in widget names,
focused widget moving down.
2: When other panel custom widget, List up 8 item  (main menu auto hide) and active show media names in widget names,
focused widget NOT moving down.
3: When I select custom movie widgets, vertical panel 1 item (main menu auto hide) and not active show media names in widget names,
focused widget Not moving down.
4: When I select custom movie widgets, List up 8 item (main menu auto hide) and not active show media names in widget names,
Can you rewrite the code, that in the first selection, not move the widget down, like in the other settings?
Has fixed on Github.
