2022-01-11, 01:02
I'm currently using the default Estuary skin, but I want to change this because I'd like to have custom main menu items for documentaries. However, when searching for another skin with custom main menu item support, I noticed that all other skins I've tried are missing the "overview" for Movies and Episodes in the main menu (marked in yellow below). I really do like this overview to see what was recently added, what episodes I'm the process of watching or which movie I watched partly.
The other skins that I checked for now (Aeon Nox, Aeon Tajo, Amber), in general, have a really bad main menu compared to Estuary, where you can easily see the available options on the left, without having to scroll horizontally. They even have main menu items that dont even fit in the menu (Aeon Nox auto scrolls them and Aeon Tajo adds "..." after an incomplete word, which totally unusable. The Amber main menu looks pretty nice, but I don't like the horizontal main menu items and it is missing the overview...
Sometimes also the other menus (like settings) are also really bad (Aeon Tajo menus often look like a MSDOS menus instead of a GUI, with a really bad overview and buttons that are practically invisible).
So I'm wondering:
1) What's the name or proper description of this main menu overview? So that I can try searching myself which skin has this too...
2) I also found posts about Estuary Mod Skin, but am I correct that this skin in no longer maintained?
3) Any advice of skins I should try? I'd like a good and usable main menu, if possible with vertical listing and a nice "overview" like Estuary. No crappy setting menus. A good listing for large collections.
So I'm wondering:
