2022-01-14, 17:22
(2022-01-13, 11:09)Maaarv Wrote: [ -> ]The 1030 has one HDMI and one DVI output only. That's why I'm a bit confused here.
Yep, but the HDMI output is internally more than one device. See this log which shows Kodi starting up on the same card and listing the five internal connections it sees. For ref, my amp appears on HDMI#1 but the passthrough capabilities are listed for each internal connection as
xml:STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
DTSHD-MA and TrueHD both work fine on that card here on Linux.
