I'm trying to play my ripped ISO images, but each time I do on either my SHIELD Pro or my Linux desktop, I get the same error message of
This video is stored on an optical disc, and cannot be played as your device does not have an appropriate drive.
Others that I know are able to play their ISOs just fine, and I know it should be doable but clearly I either don't have a plugin installed, or I'm doing something wrong. What am I doing wrong that might be causing this behaviour?
Thanks for the help.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I've figured out what my problem was. My advancedsettings.xml had
<discstubextensions>
<add>.disk|.stub|.iso</add>
</discstubextensions>
Once I removed that, I was able to load the ISOs as I expected.
You do realise that you should only be using disc stubs if you have unripped DVD's/Bluray's that you wish to add to the library.
I get that the disc stub thing I had in my advancedsettings was causing an issue, yes. I thought (clearly wrongly) that I needed that to be able to get my disc ISOs to show up in my library and be played. What is a disc stub?
It's where you do
NOT have a playable file, so where you have a large collection of optical discs e.g. dvd's but haven't got to ripping some or all of them, disc/media stubs allow you to add these items to the library see
https://kodi.wiki/view/Media_stubs
