Instead of giving the regulars options, could "S" make Kodi quit directly to the OS ? In this Case Windows?
If so, is there any xml files that I could edit?
Thanks for any clue.
Regards,
-Eric
(2022-01-17, 20:49)estarna Wrote: [ -> ]could "S" make Kodi quit directly to the OS ?
Yes.
Open your keyboard.xml file
Look for
<s>ActivateWindow(ShutdownMenu)</s>
Change it to
<s>Quit</s>
(2022-01-17, 21:02)Karellen Wrote: [ -> ]<s>Quit</s>
Wow... Thanks Karellan. It works!
I am using Estuary. Is this the lione I'm loking for to just quit Kodi when I finish watching my show?
<param name="onclick" value="ActivateWindow(shutdownmenu)" />
and change it to:
<param name="onclick" value="Quit" />
Thaks in advance!
john
(2022-08-30, 20:03)DoorGuy500 Wrote: [ -> ]Is this the lione I'm loking for to just quit Kodi when I finish watching my show?
My posts above refer to the
keyboard.xml file.
This file
may be located in your \
Userdata (wiki)\keymaps\ folder.
If it is not there, you need to copy it from the \program installation folder\System\keymaps\ folder.
