2022-01-20, 20:11
Hello Friends.
i have nvidia shield and ended up installing android 11...
since i had kodi 18.9 setup before with the media located on windows 10 (smb) 2.0, running MySql 5.7 for the database.
everything was working fine and then for some reason i had to re-format everything .. my pc and nvidia Shield.
now i'm back to same setup... windows 10 pro... nvidia 11 and kodi 18.9
Now its been 3 days and i'm out of options so trying to post it here..
installed the nvidia hotfix 9.0.1. aswell.
my problem is .. i have 3 kind of media and i use two kind of scrapers ... one is the default "The Movie Database" and Other is Universal Movie Scraper.
when i scrape using the The Movie Database ...everything works it should.. media is there, posters are there, info is there everything gets done successfully.
but when i switch to Universal movie scraper... to scrape the rest of the media .......it scrape 5-6 files... and then KODI crashes and get me to the home screen...
those 5-6 files stays... the media is good , info is good... posters are good.. everything the way it should be .. but it just crashes every single time....
Just for the test purposes... i tried formatting the shield and installed 19.3 Matrix .. exact same problem....
tried these with 10 different ways... tried it with loading transprency skin
tried it with default skin
tried it with all the addons installed(the one i use)
tried without any other addon....
tried with the database (advancesettings.xml)
tried without the database(no file)
and all the other options i could think of..
Can't use matrix because i love Transperency Skin... and can't use KODI without it... so have to go back to 18.9
Please Help.
Please Help.
