Full Version: problem network sharing
Hi everyone. I have a problem.
I have a himedia q5 box and I have a network sharing problem between my mac and my q5
a short time ago I used SMBup but now it doesn't work with 64 bits
my kodi in himedia q5 adds sharing files but the folder opening is very slow and the movies of great capacity over the 60mbps go to jerky
The sharing system is practically slow
what can it be? Why when did I have SMBup worked perfectly?
are you also using SMB now or some other protocol? which macOS version do you have?
(2022-01-28, 20:55)kambala Wrote: [ -> ][font][font]stai usando anche SMB ora o qualche altro protocollo? [/font][font]che versione di macOS hai?[/font][/font]
[font][font]yes smb i have monterey os.....[/font][/font]
haven't checked how's SMB on Monterey yet, still on Big Sur where all seems fine.
have you tried playing with SMB version setting in Kodi? for example, it has to be forced to v1 on Big Sur (and Catalina iirc) to be able to browse shares.
(2022-01-29, 09:58)kambala Wrote: [ -> ]non ho ancora controllato come sta SMB a Monterey, ancora a Big Sur dove tutto sembra a posto.
hai provato a giocare con l'impostazione della versione SMB in Kodi? ad esempio, deve essere forzato alla v1 su Big Sur (e Catalina iirc) per poter sfogliare le condivisioni.
How do I force?
(2022-02-03, 03:49)vicius80 Wrote: [ -> ]
How do I force?
https://kodi.wiki/view/Settings/Services/SMB_Client set min and max to v1
